**Urban Runner Stereo Replacement Information**
Where did you atttach the green parking brake wire. I have 2008 Urban Runner. have finished install of Pioneer 8200nex but cannot figure out the green wire. Pioneer says unit will not fully function without attaching it.
Ground it to the chassis then test the video feed (HDMI) on your unit before putting everything back together. On my Kenwood unit, it said the same thing. That wire was for my HDMI input. It makes it so the video will only show while in park. If that's really what you want, I don't recall where it's supposed to connect. I remember reading about it on here somewhere. However, if you just ground it instead, you'll have access to the feature full time (even while driving). Worked for me.... but test it since Pioneer may be different.
Hey guys/gals...looking for a bit of help/info on replacing my 2011 LTD stock NV/radio system with an updated one. Here's what it says on the window sticker off the truck about the unit, it's coded as "NV";
"Voice-Activated Touch Screen DVD System with integrated backup camera, JBL AM/FM 4 disc CD changer with MP3/WMA Playback capability, XM Radio with NAV traffic"
Big question is, will the 2016/17 NAV unit a plug-n-play replacement for a 2011 LTD:shrug:? Any help appreciated:bravo:....thanks
I just picked up a trail edition with the TomTom gps head unit. Can I swap a normal SR5 head unit out into this and have everything be plug and play? I'm not a fan of aftermarket head units and want the stock look. My prior 4runner had the basic Toyota head unit and it was perfect.
yes. it will fit. it might not be a simple plug n play though cause the tomtom unit has a different plug on the rear. you might need to cut and reconnect the wires but it will work
Hmm OK thanks. Any idea how difficult it will be to splice wires and figure out what goes where?
[MENTION=97326]JeffMerr[/MENTION] super easy to splice. you just need some butt connectors and heat shrink. there are multiple links out there (including some in my sig) with wiring diagrams.
Just want to make sure that the tomtom gps unit is not tied to my auto dimming mirror with compass? If I replace it with a normal SR5 head unit the compass in the mirror will stil function? Thanks
not related at all. I have the dimming mirror/compass and removed the unit with no issues.
Hey Jeff, I have a 2009 Trail Edition as well and am on the fence about cutting/splicing for my head unit upgrade.
Did you end up doing it?
Results?
Results?
I think you have to cut/splice since its a different harness on the tomtom units. its not that big of a deal as long as its done correctly and you aren't cutting them too short.
Agreed, it shouldn't technically be that hard with a reliable cross-reference / diagram. I found a diagram for the UrbanRunner factory wiring, but the colors don't match pin-for-pin on any of the connectors I've got... :ybrick:
I bought a great low-mileage Urban Runner a year ago and I am ready to do a stereo upgrade. I know this is slightly off-topic, but i did not want to start a new Urban Runner stereo thread.
I know I want to get a new head unit and amp. I know I do not want to add a subwoofer. I am not an audiophile nor do I need to need to crank it way up.
My question: do I need to replace the speakers, or will a new H/U and 4-channel amp provide a significant improvement over stock? Are those stock speakers going to sound pretty good with more power going to them?
If the Urban Runner speakers are the same as any non-JBL 4th gen, I suppose I should post this question somewhere else in the forum where it will get more views and not hijack this thread.
Thanks for any input!
the new HU will more than power the factory speakers. the sound quality will be just about the same to the naked ear as is with the stock deck. I don't think you will notice much improvement. you will have more control over the sound with most aftermarket HU giving some advantage.
you only need to get an amp if you are upgrading the stock speakers, otherwise might be kind of a waste to amplify them. I honestly wouldn't bother.
I recently upgraded my deck with the ddx970, fits perfectly in the dash with the trim ring. I added a back-up camera while they were installing it. I highly recommend it if you have any kind of city parking.
As for the speakers, I have not seen worse stock speakers before. When I removed them they were paper thin and I believe that even basic aftermarket speakers with a new head unit would be a huge difference. If you like to ride with the windows down after market speakers are the way to go.
Id recommend someone install it for you. The wiring harness for the urban is a nightmare
Hoping for some help here...
I just installed a Sony head unit in my 2008 urban runner. Everything is working fine (power, lighting, steering wheel controls, etc.) except now I have a check engine light on and my VSC and Traction lights are on as well. I scanned the code and it came back P0500, which is for a vehicle speed sensor. I've checked both VSS sensors on the tranny and all four ABS sensors, and everything was fine. Is it possible that replacing the head unit could cause these lights to come on?
Did you install yourself? Did you use any other add-on's? Maestro, PAC unit? I was soldering together the wire harness for my Kenwood last night and there was a "vehicle speed" wire, or something. If something like this is present in your install, maybe this is causing the issue? Worth looking into.
AndiGarage
