Terrapod
same boat with the Maf Cal. installed the Y-pipe this past weekend. you'll be happy once youve installed it.
Did you do an intake as well? If so...which one?
Y-Pipe installed.
Some Y-Pipe installation notes:
You may very well need new exhaust flange studs and nuts. Those parts numbers are the following:
Studs: 90126-10033 (x4)
Split Nuts: 90080-17187 (x4)
And...you may need the large crush ring gasket the goes between the Y-pipe and the muffler. I reused mine, but am keeping an eye on it in case of leakage.
Ring gasket: 17451 (that's the only number shown online)
Y-pipe and Skids plates:
- For those wondering if it will clear skid plates, it will. However...I have the RCI aluminum plates with the angle reinforcement brackets installed. I wrapped the pipe in high temp exhaust wrap. And...the pipe just touches those reinforcements. I plan to take the plate off and notch the brackets to prevent any issues on the trail. I'll try to post a photo as soon as I can.
C
Pics...
How's the fit with the RCI Skids? Do they clear easily or is it a close fit? The y-pipe looks well protected by the skid, but because of the reduced airflow I can see the desire for heat wrap under the tranny now.
UPDATE: Received the URD MAF Calibrator. Installed this morning and took the 4Runner over to fill up on 93 octane.
Initial impressions: Engine idles much smoother. Impressively so. Prior to install, my center skid plate would slightly rattle when in park. Now...nothing.
Throttle pedal has a more progressive feel. I have a 45-50 mile trip to do this afternoon. Interested to see how everything adapts.
More to come.
Y pipe + URD MAF + 93 octane... hoping to hear some spectacular results
do you always run 93? or just recently. I'm asking because it takes a few tanks for old octane to flush
[MENTION=148699]Terrapod[/MENTION] awesome! I received mine as well but have yet to install it. I'll probably do it on my lunch break.
So from reading your install this morning I take it you didnt unplug the battery for awhile like some of the members did?
We'll have the same exact setup once i install the MAF.
Have you thought of exhaust options?
Is it ok to leave this installed when going to dealer for service? Truck is still under factory warranty.
More to come.
Its been a few weeks, how are you feeling about your upgrades? I am considering the same route.
he went from 87 to 93 after his urd calibrator mod... so what he's feeling might simply be the change in octane
I went from 87 to 93 octane for 5 tanks (no maf calibrator) and I am certain I felt no change in terms of my butt dyno. My ear dyno heard no change as well. If there are any changes in hp/tq from just higher octane it is so slight that if someone feels the difference they have a very well calibrated butt dyno.
I am still waiting to see/hear from someone who has tried the URD maf cal on a totally stock 4r and if they have any feedback.
