Using 2X Spidertrax and 2X All-Pro wheel spacers?
okay but no one really cares that its blue???? at least i dont.
Eh...I wouldn't get them based on the color. I think blue is ugly, and blue doesnt blend with with black or dark gray. Also If All pro's offer 3 sizes I'd support them simply because they offer options. And lower price? I cant see any reason to buy Spiders.
exactly! i might try 1.25 up front and 1.5 in the rear, or 1.5 all the way, but i doubt the 1.5 all the way. and ill prob chicken out on the 1.25 front and 1.5 rear, but i will see. before i buys spacers i gotta finish my suspension.
you can see the blue spacers on mine, but a person who didn't know what spacers were would never notice.
Don't mean to hijack this thread but does anyone know if spacers are legal in Texas? I am moving from SC to there in august and SC doesn't do inspection but Texas does.
Looks nice EUY! id say 1.25 is just fine, it looks like it fills the wheel wells out good, and anymore spacing in the back would just kick up more rocks i would imagine. I like it!
i had some rubbing issue with the plastic liner so i took the fronts out. i think it still looks fine with out the front spacers.-euy
No need to take out the front spacers. There is a very easy mod J.A. posted to fix the minor rub. I have done it and have no rubbing with 265/70/17s and SpiderTrax. A dremel tool, masking tape, and a drill and you can be done in 30 mins. See link below.
Toyota 4Runner Wheel Spacers
The only thing I did different was I cut the nutserts in half and reused them after I pushed the plastic liner back a bit and redrilled a new attachment hole in the liner. Then you can just use the nutsert as a washer and nut after you cut it.
Good luck
And the Blue spacers are barely noticeable if you are not looking for them. You can not see them from 10 ft away, only if you look down inside the wheel.
ok so would it be ok if i put 1.5 all the way around? has anyone done it? i also have the daystar 2.5/1.5 lift on my 4runner right now
you might have a problem up front turning when suspension is flexing. and the tire getting into the fender. what size tires you runnin?
no problem. i dont think you will have a problem. its really gonna be whether or not you like the stance after its installed cause i have seen No one use all 1.5''. its only .5'' wider track but you may or may not like it. i think it would look good. i like my 1.25''s but somethimes wish they were out a lil wider but with my big 305's they would rub even worse.
delislerebecca
