V6 4Runners with FJ springs and 1/4" spacer
4runnerlabr
Looking for pics of V6 4Runners with FJ springs and 1/4" spacer up front and running 265/70/17's. Thinking of going this route. I've seen 8086Bruce's, which I really like and was wanting to see others with the same set up. Can anybody with this set up post pics or let me know who is running this set up? Do the 265/70's rub at all. Thanks.
Check out the link in my sig (last one, to those who've done the FJ swap) and there's a chart showing whose I have documented and info on what they used.
Thanks Ark. I've checked it out and 8086's was the only one spot on. I was hoping there were a few other V6's with the 1/4" spacer and the FJ springs as I think that's the exact lift I'm looking to achieve. I was also hoping somebody was running 265/70/17 firestone a/t's or bfg a/t's with that lift so I could see beforehand what it looked like. Anybody with that set up????
I have an 08 UrbanRunner V6 and went with the 1/2 spacer (toytec) with FJ springs and it turned out great! I would recommend the 1/2 toytec.
Before I installed my bilstein 5100s I had that setup for a few days.
FJC Springs Front & Rear, Toytec 1/4", Spidertrax 1.25" wheel spacers, 265/70R17 BFG A-Ts
edit: it rubbed pretty bad because of the spidertrax, but I've heard with BFG ATs they will still rub without the spidertrax spacers. Most other tires don't (I've read)
Thanks for the pics gaterose. I really like that setup. I may have to go with the firestones if the bfg's rub.
Bundles, do you have any rake left with that 1/2" spacer? Does it sit level or a little nose high?
No rubbing with 265/70-17's at all. There is rake left in the body but my running boards are dead level.
