V8 break in time
Hot Rod
I just picked up 05 SE with the V-8. What is the break in time for the motor. the sales rep said it was 1000 miles at 55 mph or less and no quick starts. What does she know... except what the true price of my car was. Anyone have a differnt answer or reason.
Its really a matter of who you ask...
I would say answers will range anywhere from 500-2000 miles.....
FWIW Amsoil Says most modern motors are broke in by 500 miles.
If I were you , switch out the factory oil around 500-1000K ... and use synthetic.
As per the manual, the break-in on any new Toyota is 1,600kms, or ~1,000 miles.
Basically, they just want you to drive at varying speeds and rpm levels. No long periods of idling, and no hours on end of freeway cruise control. If you're the freeway, vary your speed a bit, use 4rth and 5th intermittently.....wind it up a bit and then let it decellerate, stuff like that. Don't floor it everywhere, but don't take it too easy on it....basically normal driving.
Most of the real "break in" usually takes place within the first few miles of transporters/techs/lot guys/salespeople/test drivers flooring the thing everywhere anyways ;)
Hot Rod said:
what can the synthetic do for me? What is the price difference?
"Synthetic Lubricants are fuel efficient, extended life lubricants manufactured from select synthetic base stocks and special purpose additives. These lubricants provide improved overall performance characteristics when compared to conventional petroleum oils."
Quoted from Amsoil's website
In a nutshell, you can run Synthetic oil longer than conventional oil. It offers better protection and "lasts" longer than regular oil. Price is anywhere from $3-$6 a quart.
What does the dealer reccomend?
Honestly many dealers dont know shit about what they sell.
I recommend synthetic oil simply because you can run longer oil change intervals, it offers better protection and with the longer intervals you are saving money in the long run.
Not to mention that is typically will improve fuel mileage and longevity of your engine.
Alot of people use Synthetic, and alot of people don't. Its a personal choice. I am sure others will chime in.
If you have any more questions about oil/lubrication ... post em up!
jake
Hot Rod said:
Thanks for the info. I am new to all of this and greatful for any advice.
Follow the manual for break-in and the Manufactures recommended oil change interval if you want to keep your warranty in effect. Go to this site to learn stuff about oil www.bobistheoilguy.com One thing you will learn is that the Toyota 4.7 V8 is very easy on oil and by following the owners manual recommendations and using a name brand 5w30 motor oil your 4runner will last several 100K miles. I did the first oil change at 1000 miles and I have it changed and lubed every 4K miles. My dealer uses Castrol GTX 5w30 and I have them lube the 6 zerts on the driveline every OCI. Every other oil change I also have them rotate the tires (8K miles). At 15K have the front and rear differential fluid changed and at one year intervals change the "cabin filter". At 30K miles change the airfilter and front/rear differential fluid and also the transfercase. You can use this website to know what to do and when to do it. The V8 is very low maintaince. www.toyotapartsandservice.com
also here is where to buy your gas www.toptiergas.com this way you won't have to have your fuel system cleaned. Also the V8 runs great on regular, if you tow heavy or are doing mountain driving would I ever consider premium, other wise you are wasting your money.
I plan to switch to synthetic oil at 1000 mi.
However, I really don't believe should run synthetic longer than conventional, you most likely can, but I wouldn't.
One of the biggest reasons you change your oil is because it gets dirty right? Well, synthetic oil is going to get just as dirty just as fast as conventional oil. When it gets dirty you change it.
As I said, I do plan to switch to synthetic and also plan to stick to Toyota's 5,000 mi OCI.
Just my opinion.
Just my opinion.
Synthetic Oil doesnt break down as quickly as Dino oil. In some cases it lasts 3-4 times longer than Dino oil. 5k is not a bad OCI. However anything less than 5k is wasteful in my opinion.
I am all about getting use out of anything. thats why I use extended drains on my oil.
The only way to verify how "dirty" your oil gets is by performing Used Oil Analysis. Give me some time and I will post up my analysis on my wifes Jeep, one with Dino oil @ 3500 miles and one at 6000 miles with Synthetic. The side by side results should be interesting.
Not only does synthetic last longer and offers a extra bit of protection, it can lower operating tempatures. Many people think that oil is just for lubrication..... its #2 Job is cooling. About 50% of your vehicles cooling system is motor oil.
Additives in Synthetic oil last many times longer than Dino oil as well..
hmmm did I miss anything?
I'm sure synthetic will last longer than conventional oils with all their additives.
What I'm saying is, when oil is dirty (read black) it's time to change it, period. Doesn't matter if it's syn or conv.:)
You'll also find this thread helpful.
oils coloration as it is used has little to do with if it needs to be changed. Sure when it goes in its that beautiful golden honey color but it can remain that same coloration and still need to be changed.
My Cummins turbo diesel oil would be black several hours after I changed it, Oil color has nothing to do with how dirty it actually is, its a chemical reaction that changes the color, not dirt.
I loved my old CTD's. Had a 2000 4x4 QC dually and a 2002 4x4 RC dually, great sound (wife would not even ride in my truck). I used Rotella T (loved the smell) Does Amsoil make a diesel synthetic oil?
Yes they do, I would be happy to send you info on it.
Let me know and I can email you some info.
Jake
