V8 conversion
That is a good idea. It would help the cats be more efficient too.
Just so you are aware, there was some dicussion on the Subaru forums that wrapping the Downpipe caused intense heat to build up/remain inside the pipe and thus could cause the pipe to not last as long. It was just a discussion and no one that I could find had it happen. The wrap I used had to be soaked in water, then wrapped, then I sprayed it with a heat resistant coating. I let mine dry for 3 days before installing it. It did, at least for me keep the underhood temps down a lot. My downpipe was stainless steel.
I don't know if it is worth wrapping the cats (especially if they are not completely round in shape) unless they are close to the fuel lines as well, that's up to you. They make a muffler/cat heat shield for those. Thermotec.com (under products). For the fuel lines the Thermo sleeve is what they have. Hope that helps...
Either way, turbos produce a ton more heat than n/a motors
I do hope it gets a flux capacitor in it, maybe as an extension of the armrest.
Looking good.
For those whose V8 swap addiction is borderline rabid, I can set up a web based camera outside Singtoe's house for real live up to date progress reports. I don't know his family would like the leering eyes of fellow T4R members though.
I'm a little late to the party. Unbelievable! I have an 01 4Runner 4x, an 04 Sequoia 4x and a 04 Tundra 2x. I am used to working on all of them separately, but this combines them all.
Great work and very compelling!
Bad weather yesterday so I veg-ed out in front of the tv.
This morning, my buddy's well crapped again so I went over to help him out. So that is the story of my life, helping everybody else...
Completely off topic, but in the pictures of your Taco for sale, Is that a Porsche 944 in Guards Red behind it?
Yep. That was sold several months ago. Funny Story. I bought it for $500 (broken timing belt = bent valve) and was going to stick a 2jz-gte motor in it.
While I was looking for 2JZ-GTE front clip, Craigslist popped up a 944 being parted out. I Picked up motor for $250. Fixed it and sold it for $3k.
Anywho, Today was a beautiful day. To bad I worked to dark thirty.
Need help
This is the challange for all of you geniuses out there.
Since I am utilizing the Sequoia Transfer case, I will have to make a new Electrical relay box to replace the Transfer case ECM.
This is what i know.
The Transfer case is the same as the 01-02 4runner.
It uses a servo motor to actuate the front drive shaft. (AWD)
It uses the same servo to further lock the center diff. (4WD)
I need it relayed so that when i push AWD button and Center diff lock button, it works the actuator.
Transfercase.png~original
Do what you can, I am too tired to think about it. Thanks and may God speed.
That hurts my brain. Get a solid axle and an old school t-case so you can get rid of all the garbage. Lock the hubs, pull the lever… Done! Then you can make a pretty keychain out of all that needless wiring. See how smart I am:nerd:
Today's progress was weak.
I had a busy ass day at work.
Anywho, Here is a picture of my hoopty on 255's with my 2" body lift.
2011-12-23_08-42-03_938.jpg~original
I have 265 AT's to roll and a set of 285's on steelies for special occasions.
I hooked my AC up today.
The AC Pump is on the drivers side while on the 5VZ, it is on the passenger side. I had rearranged the plumbing on the AC condenser so that i can utilize the 2UZ hoses.
2011-12-23_08-41-06_91.jpg~original
Hose in the engine capartment
2011-12-23_08-40-51_511.jpg~original
Moving the high preassure from the right to the left and now it is from the left to the right.
2011-12-23_08-40-30_356.jpg~original
OK. Holiday rush, Shopping sucks. Got my welding wire. Finished my steering extension for the 2" lift.
Had an extra coupler
2011-12-24_10-43-56_522.jpg~original
Had an extra shaft
2011-12-24_10-47-06_623.jpg~original
Cut the shaft and the coupler and made my extension.
2011-12-24_10-50-18_467.jpg~original
All welded up
2011-12-24_16-14-22_249.jpg~original
Here it is installed.
2011-12-24_16-27-05_823.jpg~original
Got an O2 sensor off ebay. To replace the one that i stole to fix pop's Sequoia.
Cheap $40
2011-12-24_10-25-48_233.jpg~original
New in plastic
2011-12-24_10-26-05_15.jpg~original
Always use Neverseize , Denso was kind enough to send some with the kit.
2011-12-24_10-27-46_905.jpg~original
Installed, So easy.
2011-12-24_10-33-07_899.jpg~original
Some gratuitous exhaust pipe photos.:girl:
I tried to snake my exhaust so it is not the lowest point under the chassis.
2011-12-24_10-31-22_760.jpg~original
my Y pipe.
2011-12-24_10-31-33_808.jpg~original
ShiftHarbor683
