I am switching to Mobil 1 from dino. The manual calls for 6.2 liters. Do I need six quarts or should I get seven?
The manual specs both liters and quarts, which is 6.5 as progress mentioned. If you DIY and let it drain until it stops, you'll probably find you need 7 quarts to get exactly to the full mark. Similarly, I can put an extra .25 or so into our CR-V.
-Brent
I'd be careful about putting in any "extra" - that's why I always go a little under.
http://www.toyota-4runner.org/4th-gen-t4rs/26688-oil-overfill-what-could-happen-if.html
