Valve Cover Gasket job
I see no mention of the 2 cam plugs (at least in the original post) in this thread which are important.
Also, someone mentioned cracking the half moons. I almost did this until I realized they have ridges on them. Pull them straight up and out with a pair of pliers.
Orders were placed with both Amazon and Camelback, I should have all parts today, or before this weekend at the latest (hopefully)
Awesome! I was just looking at the Valve Cover Gasket set and might settle with that.
On a side note, sorry to hear what happened yesterday! Glad you made it out safe
This is on my "todo" list. Seems like a time consuming job for valve cover gaskets... but not too technical per se.
Get on it already! :) It'll take you the better part of an afternoon with some beers, it's not too bad.
Dis all I got so far
Waiting on Amazon for VCG #2 (they split-shipped) and Ebay for Cam Plugs
Started tackling mine today after work also, then saw this thread [emoji1305]
I don’t remember what brand I used but they’re completely gone and spitting oil after less than a year. Wish I saw this thread before with all the links for parts. I went with a Japanese brand THO KP or something like that.
I only ordered new gaskets and not the cams and half moons since I had put new ones in with the gaskets. Do you think they’ll be ok? Thanks.
Sent from my iPhone using Tapatalk Pro
I'm planning on spending a weekend on it and detailing the engine bay at the same time. Let's hope it doesn't rain :hatsoff:
You can do it in under 8 hours. Biggest issue for me was screwing around with that stupid plastic harness cover, trying to keep it from disintegrating which is futile. If I did it again, I'd round up some 1" or 1.5" split loom, and use it to replace the factory plastic harness cover.
Everything else is super easy.
Split loom, roger that [emoji106]
Sent from my Nexus 5X using Tapatalk
Oh, and to be really smart, I'd break up that factory harness cover into small chunks as soon as I had the lower plenum off (and intake openings taped up!) and before taking the valve covers off. That way all the little shards won't go into your valve train :).
