wfo9
Question for those who have modified things to clear large > 33" tires.
I recently got 34s and cut and moved a bunch of things around to clear them. I started on the body mount chop today and decided to verify scrub angles and clearance after doing one side (passenger). So I took out the coil over and compressed one side to the bump stops. Clearance was actually great now at the body mount (in all positions). Full lock to passenger was also fine with just a tad of rub on the plastic liner, but full lock to driver rubbed pretty bad on the washer bottle (which I really can't move easily). If I back just a tad off the bump stop (.5 or so) everything clears). My question is how realistic is a full lock turn on the front bump stop on the trail. I can't think of a time when I have turned that hard on an obstacle (since I'm usually very aware of the stress on the CV joints....). I know I probably just need to get out and try it, but I was curious if others have attempted to verify clearance the way I did.
The question is weather or not I will actually experience rub on the trail without removing the washer bottle.
It seems so rare that I fully stuff a front tire (although it does happen I'm not sure if it is actually to the bump stop while crawling) and to be in a full lock at the same time seems unrealistic.
