Very hot drivers floorboard?? Help!
doublezips
Driving distances my feet are on fire. Is anyone else getting this and what have you done to fix it. I turn the air on and even put it at my feet but the heat just over takes it.
Sounds like the cats on the left side might be the issue, is the heat shield still on the cat under the drivers floor board (there isn't a heat shield on the passenger side aft cat fyi) You should have your dealer check it out.
Most likely a clogged catalytic converter. Better get that checked out ASAP, I have seen vehicles catch fire from clogged cats.
