Volant Cold Air Intake
Got it running, make sure the hole in the MAF is faced towards the filter.
Thanks to Mole for posting his number and Jason for always making himself availble for his customers!:D
Just took the first test drive. I am impressed, the sound with my magnaflow exhaust is just mean!! Now to see if it helps the Gas Mileage.
Not to likely to show any improvement soon, as I think my foot just got heavier!!
What's the ol' butt dyno tell ya? :awais: Any more get up and go?
butt dyno feels a small improvement.
but this was in 60 degree weather and fairly humid.
I am not expecting a gas mileage improvement though.
Casper said:
anyone want to drive to vegas and install it on my truck for me?
I'm going to be in sin city or henderson memorial weekend.
if you're serious i can lend you a hand, in exchange for a few chillidogs at Sonics.
mmm sonics.......
I can feel the difference in sound. Under full throttle, you can hear the air being sucked in. It's not as loud as a K&N intake. Just loud enough to be noticeable.
Maybe it's my imagination, but I think it changed the exhaust tone too. Can't describe it... It just sounds louder. Maybe it's the combination of the two (intake & exhaust) working in harmony. :p
As far as the butt dyno goes: It feels faster! I turned lots of heads when I put the gas to the floor. :biggrin2:
I didn't get home until 2 last night, so I couldn't post the pics. I'll post the pictures tonight if my wife changes her mind about going to the movies. :bash:
mole: The 1/8" hose fitting was too small like we said. So, I used a zip tie as well.
Here is a pic of the CAI installed
volant.jpg~original
This shows the clearance (or almost lack of) at the fan
FAN2.jpg~original
Here is where I was able to re-mount the ground from the MAF
MAFgrnd2.jpg~original
Here is a new 1/8" breather tube. I also added teflon tape to the breather tube screw in connectors. Seem too loose for me.
Breather2.jpg~original
Hmm...
My mass air flow sensor looks different than Bala de Plata's. It's bigger. Also, the wire harness points to the firewall, not forward like Bala's.
In the picture looks like it's flush with the air duct.
Mine has a protrusion and can't be attached flush on the air duct.
Different mass aif flow for different year, maybe?
I am sure they are different D. Six months ago I tried to install a K&N FIPK for your year. They only problem was the MAF hole they provide was round (if I remember correctly). I modified the hole to fit mine and it worked. But after 500 miles on it, my engined rejected it for some reason and check engine light came on. I was able to return it, so no loss.
:cool:
mmm sonics.......
Let me know when you are going to be there...i may or may not be around due to trips with the aircraft but if so, im down for grabb'n a beer or what not.
Sounds like they kind of rushed the production and need to take a step back and deal with some minor issues. Not surprising.
man... once you hit around 3.7k rpms vvt-i kicks in...
somewhat similiar to honda's vtec.
once you get into that range, it rips fast to redline cut off.
The gas station is really going to get to know me now...
im starting to get a little worried....
if some one who has intalled please help me out
i think ill be going to my uncle's shop....to get it installed
HOWEVER
if some one could give me a list of possible problems and or TIPS/ trouble shooting
to allert them of i would be very thankful
thanks in advance
schwalmy
Well I think I'll hold back ordering one until the apparent problems are solved. I don't want to pay almost $300.00 for a rushed product. I'm wondering if anyone could fabricate an aluminum pipe (I know metal gets hotter than plastic) and solve the problems off the plastic unit.
After two days of driving with the Volant installed, I dont regret a thing. Theres nothing like stomping on the pedal at a light and the roar coming out of my truck. All heads turn! I definitely feel a quicker response once it hits about 2k rpm and then it continues to fly through the gears. It seems that the ecu may be picking up on the change cuase it just feels different then the first day (quicker) but it could be me. Either way, I like it!
But anyway. I feel since I helped cause the concern the rest of you have, I will now try to dispell them. First and foremost, this is an install any novice can do. Just know that before you start, have on hand some basic tools and pick up a 1/8" vacum tube about 2' in length (this will be more than what you need) and thats really all you will need. I also dont think the gap at the opening into the ram filter box negatively affects the performance. When driving at speed, my opinion would be that the force of air from the fender has higher inflow and there would be more pressure inside the box as to not allow engine heat into the box. At idle it could, but at idle the whole system is subjected to engine heat. One of my buddies that is a wrenchead and is really into building his own offroad beasts feels the same way when inspecting my install. Next, to correctly install the MAF, you will need to disconnect the ground and relocate it (you should be able to tell where there is an existing threaded hole from my photos posted earlier). When you install the MAF, be sure to remove the stock gasket on the base of it (it is pretty small). If you dont, the seal Volant provides you with, will not sit properly. And make sure that the hole in the side of the MAF (its only on one side) is facing towards the air filter. Then make sure it is seated well and then screw it down into place, but dont overtighten! Your screwing into plastic and you dont want to strip it out. Next, when you install the breathers/vaccum hoses, I found the one they provide you for the 1/2" is not necessary. The stock one fits better in my opinion. Now on the 3/8" and the 1/8" input nipples, I removed and added some teflon tape to tighten them up. I dont think this is really necessary, but I did it. The other thing to look for is, when you install the intake tube to the throttle body. Make sure you push it close enough to the throttle body so that it clears the fan and then tighten the clamps. Once these are tight, I really dont think they will loosen. Just rotate the fan by hand before starting to make sure the fan does clear.
Now I did not go over all the proceders for the full install but rather the "issues" that we have had. And again, I really dont feel that any of these take away from what the CAI is supposed to do and in fact does.
And thats it! I think, if I missed anything I will edit this post.
Awesome! Great info man, thanks! I'm glad to hear that the added power is definitely noticible. I'll find a workaround to the minor issues with the install, I'm sure this is something they will work out over time.
One question/issue I hope the intake resolves is the ability for it to keep air cool enough during hot city driving to keep all the power that is otherwise lost due to hot intake charge and/or engine timing retardation. I'm not sure about anyone else here, but I can definitely feel a difference in response when the engine is getting cool air as opposed to hot air. Any noticible improvement in response and power in the city or at low speeds when it is hot out?
I will have mine on Wednesday and plan on installing Wed night. I will report any different issues/problems I may encounter. Also be sure to check my stage 1 thread for dyno results...
patnewton
