VSC lights on, have techstream data
boondocksDrew
So both the VSC lights are on. I had a collision involving the front left corner of the vehicle recently, which should all be fixed now. Replaced the power steering rack, and a CV axle with a torn boot while I was at it. Also bumper cover and front driver fender. And replaced the bent steering knuckle. Had an alignment done. Vehicle seems to drive fine.
I've never used techstream before this, but it seems to be giving me the codes in the pics. It seems unlikely all those speed sensors failed at the same time. Any chance it's as simple as a loose wiring harness somewhere? All fuses seem ok. Suggestions on what to look into?
I ended up having to fix one of my speed sensors because I had damaged the wiring while doing my ball joints. I would follow the wires from from the speed sensors on each wheel and see where the harness meets up with everything. Wonder if it got pinched in the collision or something.
Crookedcat
