Wanted: stock(ish) coil springs/shocks/struts 1999 3rd Gen in Houston, TX
AntleredRuin
Wanted: used stock(ish) coil springs/shocks/struts 1999 3rd Gen in Houston, TX
Figured it would not hurt to throw this in the 'wanted' section.
Looking to replace the stock springs/shocks/struts on my 1999 2wd 3rd gen. Have 165k miles and everything is shot. Not looking to spend several hundred dollars on this though.
I don't really offroad, but we do have some land that I drive on occasionally. So don't need a lift at all; I really just want to get back to original stock height. I bottom out the front like crazy and I'm riding on the bumpstops in the back. I'm not against a slight lift, but it's not strictly necessary.
I don't mind used parts (provided they work) and I'm going to start hitting up junkyards in the Houston area as well.
I've seen several ads on here for 'known good' items that the owner replaced with aftermarket and doesn't just want to throw away. Suspension, running boards, ETC.
Really anything is better than what I have now, so I'm not too picky.
Any takers?
Just a suggestion but you should get some Monroe quick struts from a parts store. They are super easy to install. And everything is brand new. I used these on my Camry before it was killed by a deer. Rode super nice.
Fronts
I have a set of NIB front struts that I purchased for my 1999 2wd SR 5.
I will check the part numbers tomorrow when I get home and let you know.
W
I will eventually within the next couple weeks have a set of 99 front talls. I just need to find the time to remove them
I have front struts and coils in my garage that I just swapped. They have spacers too I can send. Cost of shipping and they're yours, I certainly don't need them. Might be able to find the rears but not sure, if so they're yours too.
I'll take them and PP ready. Messaged.
