99Yotarunner
Hey guys, i have a 99 with a auto tranny. i wanna change the fluid or get some advice if a should or shouldent change or fluch it, it has 146,000 on it and im not sure if its ever been done, i was going to pull the pan and clean the screen then just refill it and run it for a while then change the fluid a few times to let it work out the old fluid, iv also herd its bad to have them flushed, im unsure what i should do, reason i ask is when truck is cold and you take off and come to quick stop it almost acts like its in nuetral for a sec then jumps into gear, but only when cold and you stopped quickly almost like its not down shifting soon enough....its got me confused and help or suggestions from any one would very much be appreciated......thanks guys
