Warn winch rebuild and DIY in cab control
Hyde802
I got this winch a while ago, its a Warn XD9000i. I got it from a trailer dealer who took it off a trailer some one traded in. They didnt know if it works or not, just wanted it gone, so I got it cheap. Perfect.
warn_zps1ce01c3e.jpg~original
Well it didnt work. Haha. All it would do is click. The solenoids all check out, but the motor wouldan't spin. We took it off to find it seized from corrosion and all 4 of the brushes were frozen.
110_0165.jpg~original
110_0167.jpg~original
Even though they were corroded, they didnt look to be in bad shape, so we took it apart, cleaned it and put it back together.
Then decided to take the other end apart and re-grease the gears
P2210243.jpg~original
P2210244.jpg~original
232323232%7Ffp%3B57%3Enu%3D46%3A%3B%3E3%3B6%3E259%3EWSNRCG%3D3542329956335nu0mrj~original
All greased up and ready to go back on.
I got a free cable from a friend with a broken winch, roller fairlead for $1 at a yard sale, spent about $25 on a hook, hardware, and electrical connectors, and it works! I did however, have to build a bumper to mount it on using the TG winch mount.
P2230253.jpg~original
winchin1_zpse0f211af.jpg~original
The top part around was a little bent so the stock solenoid cover wouldnt fit, so I just made out of some sheet metal we had lying around.
I quickly got over having to pull out the controller every time. Did the run it under the wiper thing to hold it out of the way.. meh.
Saw this on the web, and I was sold.
232323232%7Ffp%3B83%3Enu%3D46%3A%3B%3E3%3B6%3E259%3EWSNRCG%3D3547429749335nu0mrj~original
Parts list includes.. 1 20' 3 prong extension cord, 1 trailer wiring kit, 1 2 way switch with safety cover, and 1 three position momentary toggle and some diamond plate.
I used the extension cord because it 3 wires wrapped and protected, and readily available.
Starting from the winch and moving back to the cab, I cut the one of the ends off the extension cord, stripped some wires and attached it to the winch.
This picture is stolen from 4x4 wire, as I didnt take one. Opps.
wiring.jpg~original
Next, cut the cord about 2 feet away from the winch for a quick disconnect, using 3 of the 4 pins on the trailer connector. This way if I ever want to take the winch or bumper off, I dont have to un-do my wiring.
P4210773.jpg~original
Ran the rest of the cord through the firewall and in to my open dash spot. Cut the Diamond plate to fit the DIN opening, drilled 2 holes for the switches and wired them up. Works Mint, I never have to go digging for the remote, and I can still plug the remote in if I wanted to.
P4210772.jpg~original
Flip on and go!
P8111279.jpg~original
Nice job.
I'm local to Warn, they'll rebuild them for free, but shipping would be a deal killer.
nicely done.
i had an incab switch on my last winch aswell. i loved it.
i had to replace the winch, due to severe multiple overheatings... and have yet to wire the switch for the new one.
Had to pull the bumper off last night to get at some stuff, VERY glad I put that quick disconnect on the in cab controls. Pulled 3 wires and 6 bolts and bumper and winch were off!
Heavy SOB though.. I think some synthetic may be in order if I can find a good deal on some...
Hey, got a closer pic of that plate you stuck in the DIN slot? Did you just screw that into the face, or how did you fasten that in?
The din slot/pocket is still there, I just drilled a hole in it for the wires to come up throuogh. I didnt feel like taking the dash apart. I just notched the plate on the sides and screwed it into the sides of the pocket with just 1 screw on each side. Works mint.
A few months back, when I would try to run the winch it would draw so much load that it would kill power to the truck.
I took the motor off to find a wire had rubbed raw inside. Warn doesnt just sell motor parts, and I didnt feel like shelling out 350 for a new warn motor. The internet led me to DB electrical, which had motors for $82 bucks shipped to my door. Took my chances and went for it. So far it works great. I have about 3 light pulls and 2 heavy pulls on it, and works just as well as the warn motor ever did. Only time will tell!
temporary_zps6kok0flq.jpg~original
temporary_zpsaw2idhbt.jpg~original
The bearing in the motor was also in very bad shape. We had to pull the winch apart and hammer it out from the back. Yay Rust!
temporary_zpsieeixngk.jpg~original
And the DB motor!
temporary_zpsiciptgon.jpg~original
DB electrical makes quality stuff. I've been using one their high torque $100 starters on a 13:1 comp big block race engine for about five years with no problems. I run their high amp alternator on a '69 Chevelle my wife drives and it's been awesome, I'm happy with their products and customer service. Nice to know they sell winch motors too, I didn't know that.
Good job on reviving the winch! Nice to see people finding parts and re building stuff still, so many people just toss things away these days.
Thanks! Good to know on DB! Cant beat their prices.
I rely on other tossing broken stuff. Its how you get the good deals!
new2yodarun4her
