Washer spray nozzles
I know this is posted in the 3rd Gen section, but as a heads up, the 4th Gens have the hose barb pointing straight down, and not at a 90 degree angle. So while they will fit, they really aren't plug and play as it puts a nice kink in both the hoses.
Will have to continue searching for a suitable replacement.
I replaced mine in Tetanus 1 I need to adjust them slightly. It is good to have 6 streams of washer fluid instead of 4. I am sure will be a big improvement in the winter slop this season
Got mine replaced this weekend. A lot easier than I thought. I used a small flat head screwdriver to press in the clips 1 at a time. I tried using small pliers to press both clips at the same time but couldn't get the pliers to fit. Much better spray pattern.
I installed the Odyssey sprayers on Saturday. What an improvement! I adjusted the nozzle as high as it would go and it's perfect.
I used a small flat head screwdriver to press in the clips 1 at a time. I tried using small pliers to press both clips at the same time but could get the pliers to fit. Much better spray pattern.
I tried pliers at first with no luck. I did the same as you, one side at a time, but using a plastic trim removal tool with a flat blade.
I'll echo the thanks for the research and write-up! Ordered a set as well! Just happened upon this thread while looking for something else, and it was an opportune time since one of the nozzles on the right side just ceased working.
I'd be interested as well to hear what kind of options we have for the rear nozzle. I did the rear wiper mod and the wiper does not make good contact with the window, so I'll be going back to stock, but also would like to swap out the sprayer as well if possible.
What is the "rear wiper mod" you're talking about?
Well I drank the kool-aid, and these sprayers are great!
Thanks for the pics. Older thread but looking to do this ...are you still happy with this mod? Do the Odyssey nozzles cover the same footprint of the Toyota ones?
Yes, the Honda nozzles are 100% badass and a very worthy sicmod.
Was just thinking of this discussion as I used my wipers and spray nozzles after some recent CA rains (rarity here), and was pleasantly reminded of how well they work.
As [MENTION=167832]Rallysport[/MENTION] has mentioned, I’m going to go ahead and acquire 2 of the 76810-TK8-A01 nozzles. My best friend of 22 years, a Honda technician, is going to grab them from work for me and I’m gonna pay him at whatever discounted rate he gets them at, plus a lil tip for the hookup. Super stoked I came across this mod!
Has any one tried replacing the rear sprayer nozzle? Do we think the same Honda part would fit back there?
This^^^ the oem squirt guns back there aren’t quite cutting it lol
Check RAV4 nozzles. Those are a popular update for the 3rd Gen front sprayers,.maybe the rear will work too (or can work on our rear)
Sent from my Pixel 4 XL using Tapatalk
seltzernator
