WeatherTech In-Channel Vent Shades: Need to trim?
tvpierce
Just got a set of WeatherTech in-channel front vent shades. Driver's side went on without issue. Passenger side seems like it's about 1/2" too long... and can't make it go in the channel at the front of the window.
Anyone else had this problem? Were you just able to trim it and have it work?
Thanks in advance!
Ive got the same ones you have, and the install was a breeze, took me maybe 10 mins to get them all in and they fit perfectly. Just remember when you do get them in, to leave the window up for 24hrs for them to settle in.
good luck.
Maybe you could slide the rubber up the front track, and work it up to the top corner of the door/window. That might be enough to get the room you need. I know the rubber gets moved around with time.
Also interested in installed pics! I need a set of in-channel vent shades.
I'll take another whack at it this morning to see if I can get it to work.
Will post pics when finished.
OK. Took another stab at it. I guess my advice would be to install it like I own it. :gun4:
It was a little disconcerting to bend it, and man-handle it as much as it needed. But the vent shades are made of some tough flexible stuff. Went in fine, and don't appear to be having any issues with windows rolling all the way up.
The fit and finish are very good. I would recommend. Pics below: (not sure why the IMG links won't work... so changed them to URLs)
https://drive.google.com/open?id=0Bz3iNhfJDDymYnpDMWVKd3RyNzBISlFoVjlsd29hbmI0S3BR
https://drive.google.com/open?id=0Bz3iNhfJDDymRllROGJ1OGcxMGxRZWJ5Nl9kQnl4Z0hDYUJ3
https://drive.google.com/open?id=0Bz3iNhfJDDymOTNHUmtQTG9nZ3NsMWQtSjl6d29EUGNIQkdz
https://drive.google.com/open?id=0Bz3iNhfJDDymM0JKcnZieW5JSHF5VGhITGRGNzZKYWdJUHZn
https://drive.google.com/open?id=0Bz3iNhfJDDymQUs4eHNqOWFXNGRpTTF0WE9naE5vVGJoMWFv
Those look nice! Thanks a lot for the pictures.
Definitely on my to-do list [emoji1360]
Wish I was putting them on an 01/02 Thundercloud Sport [emoji41][emoji1362]
You may have just sold a set for WeatherTech with these vents..
Would look great with my Christmas present!
wwarren702
