What are my chances?
Will they come out?
  • They will screw out no problem.
    Votes: 8 32.0%
  • I am screwed.
    Votes: 4 16.0%
  • Bacon will fix it.
    Votes: 13 52.0%
  • Total voters
    25
Probably something close in torque to the valve cover bolts. If you could even use an impact driver that would work well too.
If you use a ratchet, put a long extension on the handle for a little more leverage.
Good luck. Nothing makes me cuss more than rust.
:reddance:
Anyone know the size of these bolts? They seem solid but heads are a little smooth.
I am kinda disappointed in my torque wrench. I did not realize the lowest setting is 120 inch lbs so I had to use my guess-a-matic torque wrench and snugged em to what I think was somewhere between 30-50 ft lbs.
Everything went back together like butter and truck starts right up. I got some spare time so I am undercoating the truck with Fluid Film.
So for anyone who is struggling with rusty bolts I highly recommend Kroil and Bacon.
Good to hear it went back smooth, did you find replacement hardware or clean and reuse the old stuff?
I'm guessing you meant inch lbs.
:reddance:
they are weird little bolts
it's been a while but I think they a M4 x 1.0 and only like 10mm long. I grabbed some from home depot and they worked fine.
the ones I used did not have the jis head just normal bolts.
Deno91
