What are the largest wheels/tires i can install on my 99?
I see you are in Canada, 3.250 x .03937 should give you your mm equivalent.
:biggrin2:
I agree that the spacers are the least expensive way to go.
racedirt1 said:
6 on 5.500 is what you need, you got the right ones. You could get by w/ the 1" but I would go 1.250.
Excellent! Thanks. I was thinking 1"but the extra 1/4" may give me some piece of mind.
The only problem now is that if I use spacers my tires will stick out past the chrome fender trim and if I do that than I have to find some nice fender flares...... :bash:
Jerry
jspagna1 said:
Now if you went with a 265/75/16 that would take up more wheelwell space. The tires would be a bigger diameter and therfore with your lift kit, you would have no rubbing issues and again, it would fill more of the wheelwell.
http://www.1010tires.com/TireSizeCalculator.asp?action=submit
Hey thats a good tool. I do like the 285/75 r16's because they are wider, taller and depending on the brand....BFG AT's have a agressive tread look to them.
