What are you pumping into your V6
SPRUNNER
I have a Rav4 and I'm looking at getting a 4runner. I want the V6, just wondering what every one is using for gas.
In canada
we have
87 89 91 octane
I tried to start a poll but couldn't get it to work.
Mostly Premium, But I want everything I can get out of the engine power wise. At High RPM it seems to pull a little harder with the Premium. Just my opinion and you know what those are like.
(oYo).
I run the premium, but I have a SC. I ran the lower stuff and had some pinging at higher RPMs.
well i used to pump in 91 when it used to be cheap.. now i pump in 87 and actually get more milage out of it.. my honest opinion if your vehicle doesnt need premium gas dont pump it.. its a waste- plus as long as you follow up on your its maintenence schedule, it should be okay :D
I have run my 05 V6 on 87 with no pinging or knocking. The need of using higher octane is a whole topic by itself. If the engine does not require to run on high octane gas, then it's fine by just regular(87,89). FYI: Lower octane gas is actually easier for spontaneous ignition. Higher octane gas is harder for "spontaneous pre-ignition", thus prevent knocking or pinging. It does not give you performance gain, if your engine doesn't require it for its optimal performance.
87 until I changed my plugs at 36K. After that, its a mixture of 90% mid grade. Sometimes 87 and sometimes 93. Hess gasoline, cause i save 5% everytime I use the Hess card.
The manual for the 2004 T4R says 87 for normal driving so that's what I put in. I only use 89 (or 91) when I'm either towing or up in the mountains.
