What Brand Injector to Use
tryan68
I have a dirty injector that is malfunctioning and causing a misfire on cylinder 1. The coil is still good as the injector is reading between 14 and 15 ohms. I have narrowed it down by swapping coil packs and spark plugs. It has a new set of wires on it. I can also hear the difference between the good injector on cylinders 3 and 6 and the faulty injector on cylinder 1 when the motor is misfiring. Im looking to find a good brand that works well for our 4runners. If I need to go Toyota original I will, but I don't want to spend the extra cash at the dealer if there is an equivalent alternative for less.
For an injector, I would try to stick with Denso. That's a pretty important part. I thought I had an injector going bad also just last week and was looking into them. If I had one that I knew was bad, I would look at a place on ebay called cs performance injectors. For $120, you get a set of 6 denso injectors that have been flow matched, cleaned, new O-rings and filters and they come with a 3 year warranty. That's still less than the price of one through Toyota and you know if you have one going bad, the rest are probably not too far behind it.
I've always had good luck with Beck Arnley products but they aren't much cheaper than Toyota.
I don't know dude , I would be quite AFRAID to go near any injectors off of EBAY.
Just use the forum search here to look it up. There are plenty of horror stories where people bought EBAY injectors and everything became worse.
TerryNap61
