What could cause 07 4Runner 2WD SR5 driver side rear window to go down on its own.
jow
What could cause 07 4Runner 2WD SR5 driver side rear window to go down on its own. I hope this will only happen while the switch is on (for security while I search). Who has seen this problem and what was your issue and fix?
I feel it will be a short but where? This 2 yr new to me truck is scaring me since my past truck was total due to a shorted ignition causing a dash fire.
Thanks For Sharing!
Fixed I Hope! After finding in the “daylight and morning after”, a tool basket had slipped. A friend made the best suggestion by saying, “You Are Causing The Problem”. My inspection showed a tool’s handle directly on top of the switch due to shifting to the door (attached). Too Busy To Check For Little Things First!
youngrk
