These came in today. Getting installed in the morning. TRD Pro wheels and K02's on a non pro? I know... nevabendunbefo.:lmao: It is almost impossible to find good looking wheels that don't have ugly fake beadlocks. Might switch to RPT1's later.
Love the Pro wheels...
Installed a dash cam tonight because I almost got into a serious accident 3 days ago. Direct wired with a parked car g sensor over ride function. Good stuff.
Just got done installing my spidertrax wheel spacers. Made sure to use the supplied thread lock and torqued them to 90 ft lbs as mentioned in the instructions. I guess the process is to remove the wheels after 50 miles and check the torque on the spacers by seeing if they can be removed at 80 ft lbs torque?
I miss anything?
CaliRaised - Low profile hood mounts and ditch lights with side projection
Baja - Amber sport wide cornering
Grand General - Amber marker lights
Aux Beam - 32” 5D-Series Combo (PROJECTOR LENS)
Rago - Behind the grill mount
Overland Eqipped - Auxiliary Fuse Block Bracket
Blue Seas Systems Fuse Block
Buss Bussmann Circuit Breaker
Man... that turned out super clean! Good work!!! :thumb:
This looks really nice, especially on your Super White. Great job.
Hope you don't mind a few questions. Where did you mount the relays? What did you end up using for switches? Any future plans for the rest of the open fuse terminals?
NICE!!! I did just about the same thing but with a powertray. my only advice would be to label the fuses, after you get past 3-4 they get hard to remember (then throw in some time) and you could find yourself swapping out the wrong fuse wondering why it doesn't work. ask me how I know?
Finally got around to installing my Bilstein 6112's up front. Sticking with the 5100's in the rear with a 2" spacer and Airlift bags.. I was debating pulling the bags out of the springs and installing them into some Ome lift springs, but figured that would be a major PITA.. Has anyone ever removed them before?
Finally mounted my Rago storage panels! Cleaned up some of my old army molle pouches to hang stuff up, just need to get the fire extinguisher. Now my dog has room in the back and my side windows won’t get covered in dog saliva hahaha
I went camping a few weeks back! Going again this weekend!
Got the wheels and tires installed this morning. Much better than the factory 20s. Sure wish I knew why all my pics are upside down all of a sudden. Wtf.
Stage 7 and New Wheels/Tires
Now time to test it out
Thanks!! The relays are tucked in the side. Kind of keeping everything clean. I went with the 5th gen style switches. A roof rack mounted light is next. Haven’t thought past that. Lol
Wouldn't you just look at the fuse and see if it had burnt to determine if that's the one that needs replacing?
ever have a fuse burn out that looked fine? ever try swapping a fuse because something didn't work to make sure the fuse was ok?
Honestly can't say that I have. A fuse is either going to work or not. Electricity doesn't care as long as it has a path from point A to point B.
New shoes! FJ Cruiser 8-holes with 255/75/17 Duratracs, 1" front spacer.
What mounts or how did you get your paper towel roll on the Rago?
Thanks!
Jhunt
