Made an appointment for window tint, ordered an N-FAB nerf bar, took it back to the dealership to redo the Eckbond on the interior, canceled the N-FAB nerf bar order and went to the wheel shop to look for some new wheels and tires..... and was informed by the salesman that the shift lock cover was in a bag in the glove compartment.
Send her over to talk to my wife...i haven't been able to sell that one yet!
It's taken me two years of positioning and casually pointing out the benefits at the right moments to get to this point. It also doesn't hurt that it was the right pricing for us.
Can I ask which shop this is? Thanks.
Trackside Motorsports in PDX, ask for Garth.
Looks good, better than my clamp on mount. How did you fasten it to the inside of the rail?
Now you need to upgrade your flag.
I took a small piece of flat bar, drilled holes to match the aluminum CB antenna mount on the outside then tacked a couple bolts through it to work as studs. I actually got wing nuts also so that I could take the whole thing off easily but they wouldn't clear the flag release.
Some kind of led flag whip is definitely a future projects.
Sent from my SM-G920V using Tapatalk
Discovered this cool hidden compartment right behind the rear seat. Because of the Weathertech cargo mat, I never noticed the small pull tabs before. Looks like previous owner didn't either. :cool:
What year is your runner?
This weekend I put 250 pounds of trimmed tri-tip beef, 65 pounds of linguica sausage into two coolers in the back of the 4Runner. All prepared by Cal Poly Meat Processing for a 500 person BBQ I cooked for!
image_zpsxd7qwe4i.jpeg~original
Nice!
Gotta have respect for my alma mater. I miss that area.
What model did you go with?
Kukenam Sky, I have small kids, it'll be tight but I have an ARB awning and room as well when all of us are out. It's a total splurge, but truly I would not have bought it if my wife hadn't wanted it as well.
Now I just need to figure out where to put the stuff that would have been on the roof. (Wishing I had the swing out on the bumper, [MENTION=124732]LawnDart[/MENTION] )
Replaced my cornfed spacers with 3" OME 885. Took about 2 hours to replace the fronts by myself.
The OME's look great! Is that the JBA UCA? Did you unbolt the UCA and swap out the Coilover or did you have to mess with the Lower Control Arm and KDSS to install the Coilover?
Sorry new to site and this stuff but I just got my wife a 2016 and I want to put a set of 20x10s on it but don't know if that will have to many rubbing issues I will be putting 33 inch tires on it should I have a issue with out a lift?
Yes JBA UCAs. I left the UCAs attached and unbolted the LCA and kdss to get the coil overs in. The install would have only taken 30min if the KDSS wasn't such a PIA to get hooked back up.
Cpn2mss
