[MENTION=112919]Salvo[/MENTION]
Damn that's a helluva baton. Definitely will keep it in mind, my only concern would be the charging system. I see most guys mount the docks in the back, I'd want my flashlight at reach to bust zombie skulls at will. Where there's a will there's a way though right?
Took her up to Lake Pleasant. These 5100s on the washboard roads were AMAZINGLY smooth!!! (edited for better pic)
The rear camera override: BriGuyDIY | Any time Backup Camera, Auxilary Video Input - Toyota
You can use any switch for the rear camera override, I used this one: 12 Volt 3amp ON-OFF Toyota OEM Replacement Push Switch with LED blue lights -Air On Board
Prestigious Society navigation nanny override--errrr, I mean, Navigation Enhancement System (be sure to enter your correct year/make/model): Prestigious Society » Navigation Enhancement System » Prestigious Society
It's not exactly cheap--$263 for the entire project. There are ways to do all this on your own if you are willing to cut, solder, etc. But I wanted plug and play and reversibility.
Thank you! It says wired switch not applicable to toyota?
Did you plug both of the holes on the lower part of the TRD CAI box?
The lower box had three holes for bolts, and I saw 1 hole on the side closest to the front bumper (used a plastic plug). My parts bag came with only one plastic plug. Off the top of your head, do you know where the "2nd" hole is located?
One of the mounting bolt holes after your rubber grommet is installed has (or at least mine had) an area where the opening was too large for the grommet to fully fill.
I used some O2 safe silicone and filled that opening to seal fully.
If your plug fit tightly on the side of the box, that's good, if not use some silicone to fully seal.
If all is sealed including the lid, it might be normal, I never heard it.
You could look here to see the thread.....http://www.toyota-4runner.org/5th-gen-t4rs/85960-how-guide-trd-cai-installation.html
Hope this helps!
Installed some keeper rings and cam buckle tie downs to secure three 68 quart totes. They fit perfectly under the cargo cover and the straps seem to hold them in place. Not sure the last two pics are rotated. Thanks to [MENTION=133864]MudPie[/MENTION] for the assistance!
MB
Love those totes, what is the brand and where did you get them?
Yep. To activate the nav override you press - - + + on the steering wheel volume control and then press that sequence again to return to normal GPS mode. For inferior (non-Toyota) vehicles, you have to place a switch somewhere on your dash/panel instead. So the install is actually cleaner for Toyota.
That sounds awesome, thanks!
Added a new piece of gear to my camping hammock setup. I think it will be a handy addition although I don't think the Pro will fit in my pack.
Installed Bilstein / Toytecs 3" lift and with stock UCAs i was satisfied how the alignment turned out.
Very nice, did you plasti dip the bumper or vinyl?
i plastidipped it, although it is a little difficult since you have to peal the tapping off right away after your last wet coat to achieve a clean line. otherwise if you let it dry you wont have a clean cut or it'll pull the plastidip off
Put my rear swing-out back on (thought it would be hassle opening/closing with a newborn, was tremendously overreacting), had my bro mount a 285/70/17 tire on the spare (previously only had the stock size) and wired up some DRL LEDs in the grille a la [MENTION=89562]bimrunner[/MENTION] (albeit not as badass overall)
This was a little bit of an exploration trip. I'm hoping to do some biking down there.
If you like white water rafting you have to go up when they release the dam, usually one of the weekends in September. There are some great class IV and V's!
Out with old Volt 4300k 35w and in with the 5000k 55w HIDs. Also spray painted my chrome rear emblems which was a PITA cutting and sticking new 3m tape back on.
Now gotta cook mothers day dinner.
Well this was yesterday, but I took the 4wd-101 class at Uwharrie Off Road Training Center. (Also nearly knocked the mesh vent out of my front skid plate... Guess its time to start shopping for new ones.)
peacefulpiranha
