I agree with this.
However, I submit to you that the "Fog light" in the 5th gen are not engineered to be true "fog" supplementary lighting... I consider them closer to a driving light than anything. Even in stock form, they are aimed quite high and have a rather high lumen output.
Do me a favor: Tonight when you are driving, turn them on and back off and notice the illumination pattern. It lights up the sides and immediately in front of the vehicle, which is a true fog pattern. The amount of light output is debatable (OEM being too much) but the pattern is not.
Love the Squadron-R Pro fog light kit! Was there any major modifications, or was it a direct fit?
It was a direct fit using the brackets included in the [MENTION=120150]TotalAutomotiveLV[/MENTION] deal
That is amazing! Could you use these in road without blinding other cars?
Absolutely not! These are way to bright to use with ANY traffic. After adjusting them last night, I was still seeing spots an hour later!
Out in the desert again
160519-Fortymile Desert Lots of sand. Thursday running in the hills of the Hot Springs Range. The interior of the area where I was a few days earlier. The weather was sunny and warm with a lot of wind.
19 May 2016 Weather sunny with cloud front rolling in; warm 80 degrees F; wind 25mph gusting to 50mph.
30601_zpstdffybjc.jpg~original
30602_zpsntyunp5h.jpg~original
30603_zps3kpou35u.jpg~original
30604_zpsfkdccr75.jpg~original
30605_zpsx4ut6jn7.jpg~original
30607_zps9ym468xn.jpg~original
30608_zps4302spva.jpg~original
30609_zpsgtsrd2ep.jpg~original
30610_zpscz44mujx.jpg~original
30611_zpsbzjrobre.jpg~original
30612_zpstubjhkda.jpg~original
[MENTION=66316]1engineer[/MENTION],
I agree completely! These are no longer fog lights, and would be blinding if used in heavy fog or snow.
And, to be honest, I was shocked at how bright they were, and how high the pattern is. According the [MENTION=87816]Baja Designs[/MENTION] web site, the pattern is supposed to be very flat.
I bought them for their additional side illumination on forest and park roads. Last fall, we were in Yellowstone on a cloudy evening, and before we got back to West Yellowstone, it was the darkest I've ever seen, and my lights on the Outback were of no more use than a couple flashlights. I used the OPT7 LED bar on the roof, and that helped tremendously. My wife was so worried we'd hit something, that we didn't stay in any park or national forest after dark for the rest of the trip. (That same night, we came cross a car that hit a bison and was totaled, so she was pretty freaked.) So I specifically added lights to the new 4Runner so that when we're out exploring, we wouldn't have to stop whatever we were doing well before sunset to make sure we we not driving after dark.
Back to your point: Ditch lights would have done what I'm using these Baja Designs fog lights for, and still left me with functioning fog lights. And I may eventually go that route. I can't honestly recall the last time I needed fog lights for fog, so I should be good for now. But your point is very valid, and should be noted by anyone looking to replace the OEM fog lights with any aftermarket lighting.
Thanks for you input,
Steve
[MENTION=135421]Ohio_Steve[/MENTION] not directed specifically at you but since you did a great job and documented this with pictures I want use your post to caution those looking to do this mod and have not thought of all the ramifications this mod will bring.
With respect to fog lights:
Too bright or too high will render them ineffective. True fog lights by design are fairly dim and aimed low as to A) Low aiming keeps them "below" the fog and B) Low output to keep the light from reflecting off the fog.
By doing this mod you have effectively deleted any true fog light function and replaced it with additional driving lights.
They look great and are really bright but they will be less effective than the stock fog lights in fog or heavy snow!
We get lots of fog (and heavy snow) in my region and there have been many times that I could only see the road a few feet ahead, and it wasn't because I needed more light! The OEM fog lights effectively illuminated the bit of road "under" the fog (1-2 feet AGL) and no amount of increased light would have made the situation any better. In heavy fog you are only driving at low speed anyway. Heck, even the Sun won't cut through fog!
Anyone who thinks this will improve visibility in the fog. It won't. Next time you are in heavy fog or heavy snow hit your high beams... you will quickly go back to your low beams and wish for something with even less of light output.
Now, the independent switch for fog light only is a good mod and needed in certain situations.
Sage words...
I agree with this.
Having done [MENTION=65614]Antman[/MENTION]'s independent fog light modification, the "before" photo (below) is with the OEM fog lights on only. They are aimed quite low and close, as intended for their use as fog lights.
tagging [MENTION=66316]1engineer[/MENTION]
I live on an island with very dense fog. These lights are useless. You can only use them with the headlights on, which compounds light output and increases lumens, rather than redirecting usable lumens. To suggest otherwise is foolish.
They're better as supplementary lights. They're great on the beach. That pattern is really great for close range illumination. But in the fog, they're bupkis.
sounds like its time for you to do the independent fog light mod!!!
:yo:
Whatever dude. If you would go back and re read the posts you see he has completed the foglight mod to make them independent of the headlights and I mentioned that.
ANY light in the fog will reflect off the water droplets. With that said, low mounted lights that shine to the sides (to see the edge of the road) and that stays 1-2 ft above the ground is the best you can ever hope for.
Tell you what - You go down a foggy highway at night with your 4Runner with no lights on. I will go down that same highway with my OEM fogs on. Let's see who gets to their destination. Useless indeed.
You need to stop flaming people, you're a mod.
Dan
Wheel spacers. Also used my 4Runner to buy a ton of shit from the new ikea in Vegas. Then I bought new g17 for work.
charlesz
