Performed the fender liner mod, making room for the 285's, did a detailed write up on it (to be published soon), and worked on drying out one of my headlight housings!
I just used a 6 x1/2" grade 8 bolt with a nylon washer in between. I haven't done a write up on it didn't know if there would be interest.
I like it because it can be removed so when you don't need/use it, it can be stored in garage. Especially important of your 4R is your dd
Installed under the hood splash proof accessory fuse box. It holds up to 4 30A fuses with total capacity 100A. Really I need it only for behind the grill light bar, but I may come up with some use in the future (maybe hood lighting). The hole write-up is here.
Open:
Closed.
Went to Last Chance Canyon about 25 miles north of Mojave, CA to kick some rocks.
29EE0CAB-6DE7-4909-AC14-CE7224A63D02_zpsxp1qmhoz.jpg~original
DSC04040_zpsebuyirot.jpg~original
DSC04041_zpsx828tp8s.jpg~original
DSC04061_zpsyeipym6j.jpg~original
DSC04082_zpsttyg5qyq.jpg~original
DSC04084_zps3zlpioj0.jpg~original
DSC04086_zpsa7syg4fg.jpg~original
C783E8B7-0130-4FDE-A6CD-9BC75435C122_zps5thd6edt.jpg~original
8A2B65DB-016D-4149-8D12-C375AC7EEC6C_zpsjf1oey99.jpg~original
After a long fun day, time to air back up.
F35F0F53-6C37-42AC-8683-DAE5002A5A74_zpsw3sjixhg.jpg~original
Got my parent's Highlander unstuck! We rolled into vaca spot after 14 hrs in the car and lots of traffic... All at our wits end. He didn't notice the drop-off/end of the concrete. Bam! Right off the end. Tried a few times to get it up, and just spun/dug a hole. I've never been more disappointed in myself for not having ordered a recovery strap and D-ring a few months ago when I was looking!! So we high-tailed it to Wally-world to use whatever we could find. Found a strap that would suffice for this one-time... Got some rest, got up, drank some beach-view coffee, stacked a few pieces of fire wood to step-up out of the sand to the ledge... Hooked her up to the Runner pulled it out gently in just a few seconds.
...then left a few pieces of wood down for make-shift chalks/stops while we're here.
2014 TEP w/ KDSS / Bilstein 5100s (front at 1.75) / Cornfed 1 inch rear spacers / 265/70 Nitto TG G2s / FN Cntrsteer Type X / RCI Front skid / Yakima Cross bars / NFab Steps
Checked the throttle body to see if it needed cleaning:
4Runner%20TB_zpsyf1589ja.jpg~original
Some smudge there, but not enough to warrant a cleaning just yet. I'll wait until I hit 100,000 then clean it thoroughly (at a bit over 63k now). But I tell you, this is the first all black vehicle I have owned, and man does it get hot. It is going to force that I build my covered drive for my auto work :clap2: :clap2: :party:
Check the differences between the hood temps, taken seconds apart, of my purple/blue Tacoma and the Attitude Black Runner:
Hood%20temps_zps9dsj2tvj.jpg~original
A few minutes prior the hood indicated 178 F. :target: I had to put on work gloves to get the air hosing back together.
Some friends and I camped up near Sedona, AZ on Friday night and woke up to meet with another at Broken Arrow Trail in Sedona. My stock Trail Premium with the TRD front skid plate did surprisingly well and held it's own next to a 2016 Wrangler Rubicon on 35's.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Took the HF dremel and went to work!
Relocated my dimmer switch then shaved some plastic to fit my ARB compressor & locker switch on my SR5.
Msh 2016
Boys trip to Mt. St. Helens
youngrk
