I've had this problem before with other vehicles. It's most likely a dirty MAF sensor.
I recently cleaned the MAF sensor, so I don't think it is that. It definitely could be a faulty sensor like [MENTION=116195]weekendclimber[/MENTION] mentioned, so I will have to hook the computer to it while it is happening to see how it reacts. If that's not the case, then I still have my money on the TPS. I never had this issue on my '99 since it did not have the DbW, but that might be unrelated.
Take a look at these diagnostics pages (for 2002, but the MAF didn't change).
my truck is starting to bog down at certain speeds and when passing. piss poor design to have drive by wire throttle body. those TPS aren't sold either. part of throttle body for 01-02.
Picked up some '99 tall springs with shocks for $40 last week. Installed them Saturday night.
Sorry, only photo I have is when I finished installing at 9pm.
Gave me about 1" of lift all the way around
Got my 1998 4-cyl grille from eBay today and test fitted it before hacking it up for a satoshi mod.
The grille doesn't clip up. The clip bosses are too fat, I need to file them down to fit the narrower clip-slots on my 99. Also, the bottom center clip doesn't line up with the car at all. Got me some work to do, but its all good.
I'm also on the hunt for grille screen and an emblem.
Sent from my Nexus 5X using Tapatalk
Supercharger and new belts
1st post so I figured it should be something good...
Installed led bulbs in gauge cluster...
Sent from my LG G6 using Tapatalk
I had all my parts for this and then the stupid radio installers...cracked my plastic on my gauge cluster in 2 spots...now I don't know what I'm going to do in regards if i change it or not...I wouldn't mind "brighter" non dull lights....Look good!
I picked up some nice 22 ga hexagonal perforated steel from industrial metal supply for about $12. Easy to bend and shape to the grill.
Not what I did, but what I WANT to do:
I have a 200 SR5 2WD with the 15 inch wheels. Thinking of putting 31X10.50R15 tires on it, specifically the Bridgestone - Dueler A/T REVO 2's here: http://www.bridgestonetire.com/tire/dueler-at-revo-2-eco
I know there will be slight decrease in MPG and speedometer, but other than that this should work perfectly with no other alterations, correct? Does anyone have any experience with this tire? I am tired of the puny looking 225's that sit on it now.
Then it's on to a stereo replacement (any suggestions?) and fixing that darn stuck antenna...
I have a 200 SR5 2WD with the 15 inch wheels. Thinking of putting 31X10.50R15 tires on it, specifically the Bridgestone - Dueler A/T REVO 2's here: Bridgestone Dueler AT REVO 2 ECO | Bridgestone Tires
31x10.5 should be ok, 265/70R16 is the factory size on most of these and people have gone to 265/75R16 without lift (most lift though) so you should be good.
For the stereo, I swapped in a Kenwood pretty cheap from best buy, and replaced my factory (non retracting) antenna with a stubby antenna from Amazon for a few bucks.
I see you're new, spend some time reading and researching on the forum here. The search feature will become your best friend. You'll see a lot of the common topics come back up over and over again. Welcome!
Start of rear axle overhaul. Serviced out to press bearing and should be done yoday.
Sent from my SM-G930P using Tapatalk
2001ATL
