Didn't do anything on it today, but spent hours trying to figure out what lift set up to put on my 4runner, what are y'all's thoughts:
-Toytec 3 inch front coils
-Tundra Bilstein 5100s all around (front struts put on the second notch)
-Toytec superflex rear coils
-Diff Drop
-Extended rear brake line
Am I forgetting anything? Anyone have any experience with a similar set up?
I would post a new thread, but apparently I'm not allowed to
for every day driving this is what I have and I really like it so far. ride is like butter.
-OME 890 rear coils (I rarely have a lot of weight in the back and do minimal "heavy" offroading)
-1" diff drop
-extended rear brake line (i noticed my stock brake like is getting taught when I jack the truck up and remove tires, so I am installing the new extended line this week.)
if you do a lot of 4x4ing then the superflex coils will probably suit you better, a lot of guys on here seem to like them.
-Diff Drop
There's no need for a new lift thread until you've searched the forum and absorbed all of the information that is currently present. I'd suggest a Sonoran Steel 1.2, I have absolutely no complaints with mine.
Lifted her up. First is before and then after. It was a pain in the ass and I might swap out the 8 wraps for something that won't give it so much rake.
Before you get going with swapping the 8 wraps I have to ask are you going with after market tire swing rear bumper and storage system in cargo area. If you are those 8 wraps will serve you quite well over the long haul, 100k miles.
Thats what I have bumper and storage and have run them that long still going strong nice ride, the extra weight will make it set a bit lower.
Finished out the art on back panels for the sleeping platform and took the obligatory camper van photo.
I Cleaned
I didn't realize how dirty this thing really was till i sprayed a little simple green....can actually see the blue NKG wires now (before I had to wipe them clean to read "NKG" just to ocnfirm they were NKG!!)
no before shots of the engine bay, but here is after. after
and all my door jams were disgusting. it was like this is every door. all better now!
Just bought the Smittybuilt XRC 9.5k Gen2 winch. Gonna end up custom mounting it under my stock bumper and have the fairlead come out where the license plate is.
Didn't know where else to put this but this Hiace Toyota van is up on CL, fresh from Japan. It has the 5VZFE engine. It is auto with AWD. I wonder if you could swap in a manual tranny and a bunch of other 4runner parts (rear locker axle?), lift it and have a great off road rig with some decent interior space. It looks goofy now but with some bigger wheels, bumpers and a lift it would look badass.
https://vancouver.craigslist.ca/rds/cto/d/jdm-toyota-grand-hiace-full/6454192230.html
Do it.
Reassembled after painting the wheels and interior. Next up will be to paint the main exterior body millennium silver (very tiny taping should be interesting) and detail the other parts (most of the undercarriage, faux-fading, black-out the sunroof, etc.). Then comes the harder bit of making tiny accessories like a ~ 1:38 scale Yakima Loadwarrior and some taillight guards. Not sure if I'll have to hand paint things like stickers on, or if I can print really tiny ones (even size 2 font may be too large).
How cool! Where did you get the models? I’ve been looking for a white 5th Gen that I can mod like my truck.
So I got a little too aggressive with my skinny pedal last time at the off road park. That spurred replacing the old worn out LCAs, steering rack, and now the broken IFS axle.
This...
https://youtu.be/f1VLKM3dIBk
Did this...
I did drive home on it without an issue and it was not until I swapped the CV axle that the missing teeth became evident. Hopefully it will be back on the ground doing DD work again by Wednesday.
In the last 7 days it has received new Toyota LCAs, steering rack, all LCA adjustment parts, and the original IFS axle back in it. Also swapped in a new CV axle from O'Reilly's to replace the one that got messed up on the hill climb.
I want to at least see an engine bay pic or two.
The door looks practically brand new with a little work. Where did you find the new rubber? This is something mine needs, bad.
Ah, it was such a change I thought it was new! I'd be interested as well. What is currently out there is out of my price range.
Finished valve cover gaskets/seals, painting valve covers and intake, knock sensors, knock sensor harness, fuel injectors and misc hoses throughout.
Need a new radiator cap as I noticed the spring on mine is missing.
Next up is the timing belt.
Thanks everyone for the awesome write-ups and helpful posts. Makes working on and keep a 20 year vehicle on the road that much easier. :cheers:
Ambrose67
