Status
Not open for further replies.
Don't forget doors are decently heavy and apply a ton of leverage on them as well.
For sure doors equal a 42" cheater bar, hand/finger pressure misleading.
Holding check against bench my body positioned to be pushing with legs check arm didn't budge.
As much cheater as I could muster. The check internals are holding the arm very solid in the case.
I'm not seeing anything that make these a bad choice, long as they bolt up. Shade Tree review.
Sounds like you have a block somewhere. If it whines with tires off the ground then it's very likely.
Unless you're using PS fluid instead of ATF, then that's certainly your issue.
The guys running 37s use factory pumps so overall delivery shouldn't be a problem, especially if you're on 33s like 75% of users here.
I use dex 3 ..just going to flush again and see what happens
We are almost twins here. Replaced my O2 sensors a while back due to a random P0420's here and there - then it got worse! Cleaning the MAF is a good idea - that may never have been done on my truck.
Also, I just replaced all the bushings on the rear suspension and have some 906's that I'll be putting in tonight to replace the '14 4Runner springs I had been running previously to button up that project.
-Charlie
Unfortunately the code came back on. At this point I think I may just have to live with it if I don’t want to replace my cat. My gas mileage and power seems fine but at this point and I feel like I’ve combed most of the previous forum posts on the code with no luck.
How did the 906’s look once installed? I sent back some cheaper shocks I ordered and got in some 4600’s. Still waiting to get those installed.
All good. I left in my 10mm trim packers back there and it is sitting around 22-22.5" hub center to fender lip in the back. I expect it to settle a bit. Did an easy offroad trail over the weekend and it felt good. The new bushings are a revelation on the highway and over uneven pavement - but now it highlights I need to do some work to the front end. :frusty:
-Charlie
-Charlie
Hey Dude,
Why did you replace bushings instead of going with upgraded links? To me, it's an awful lot of work for no gain past what came from the factory. The factory lower links are a weak point on these trucks. You have upgraded, taller, heavier-duty springs and shocks. Why not upgrade the links while you're at it?
I went through 2 sets of factory lower link bushings. The SPC lower links were a HUGE improvement over the stock arms/bushings. The Mevotech Supreme upper links were also a noticeable upgrade as well.
Just curious why you went the route you did.
I haven't bent/damaged the links in the last 320k miles... The bushings were worn, though not totally shagged. My total cost was $150+ shipping and not much more labor than swapping out links. SPC lowers plus Mevotech uppers is in the $400 range.
I'm looking for control and consistency in the back, not total total flex or ability to handle rock hits.
-Charlie
-Charlie
I got the control and consistency with the SPC and Mevotech parts. Much more than with the stock hardware, plus better off-road flex. I have a Yukon Grizzly rear locker and the upgraded parts deal with that much better than the stock rubber bushings and arms ever did. Plus, the truck stays a lot more level with the extra flex in the rear now when off-roading.
I paid $192 for the SPC arms at O'Reilly's and about $92 for the Mevotech parts. The SPC arms are $234.99/pr at my local store right now.
I'm glad you're happy with your setup. As I said, I was curious why you chose not to upgrade.
Cheers
Finished up my bi-LED projector retrofit. Used a DDM Tuning 3" kit with Nissan Maxima shrouds. Didn't do any angel/demon eyes or black anything out or anything extra. I wanted simplicity.
I had a 2.5" HID retrofit before but I was never really happy with them. Couldn't get them dialed in and the housing were always misaligned with the grille and I hated not having the ability to flash with the lights off.
These aimed very easily, the housings now match up to the grille, I have flashing ability back, and they are way more crisp and clear.
My tire fell out, axle and all. Need new rear axle assembly
Just purchased this beautiful 1999 IJM Runner 3 weeks ago back home in Idaho. Drove it across the country to school in Arkansas in 3 days. After the 2000 mile journey(with our only issue being ABS engaging during heavy snow and refusing to disengage, I unplugged the ABS to resume normal braking), the drivers rear tire was made a screeching noise at slow speeds, like going slowly through drive-thru or beginning accelerating. Didn’t affect how the car felt. The screeching noise stopped a few days into school. And today, she wouldn’t shift into gear at all. This was after parking her, so I thought she maybe needed a jump? At this point, the major issue was showing itself. I pulled out of the parking lot and into the lot of university’s gym, and on my way out of that lot, my car wouldn’t climb out and into the road. I threw her into neutral and let her roll down the hill and gently back into the gym lot away from traffic. We called a friend over to check it out and it wouldn’t shift into gear anymore. I thought I might’ve messed up my tranny, but didn’t see signs of it. It shifted into 4WD and started going forward and backward. 2WD was not engaging. I pulled out slowly in 4WD to park it near my dorm, and as I turned left my driver’s left tire came out, axle and all, while I viewed it out my left mirror. The axle came clean out, and the end rested on the road. Going 5mph when this occurred, I came to a very clean stop, I’m surprised I didn’t even hear the ‘tink sound when the now 3-wheeled vehicle came to rest it’s 4th point on the brake drum, still intact. I got her towed, and she needs a completely new rear axle assembly! Thankful this didn’t happen at ANY point on our journey across America. I’m on foot for now but I stay runnin, you all do the same.
TLDR: Just purchased a 99 runner, ran from ID->AR in 3 days, then my tire came out axle and all when I got to school. Need new rear axle assembly!
those look good, i may end up doing the same thing on my 98
How did this even happen? Did the studs on the axle break or the nuts came loose and fell off or maybe the bearing failed?
New plugs, coils & wires
Just after Christmas I bought a ‘97 SR5 from my neighbor. It chugged like a cylinder was missing but I know my neighbor does zero maintenance or troubleshooting. This was his fourth car… if the other 3 didn’t start this one always did so it saw little use.
I started with the drivers side middle cylinder plug and was able to spin it out by hand, no socket wrench needed. The other 5 were tight. When all was said and done this thing runs as smoothly as my ‘07 which is great!
Got all the dog fur vacuumed out and the dash cleaned up. She’ll never be beautiful but runs like a champ now.
Next is the brakes!
Judging by the backing plate still attached to the rear axle housing I would guess the rear wheel bearing failed and allowed the axle shaft to come off with the drum and wheel.
Took her out to explore our new digs in Portland after the crazy wind/snow/ice storm of the last few days. This is a major road near us, complete with a 150 ft tree laying across it (and a car smashed into it):
And another monster tree that miraculously fell right between our house and the neighbor's house:
This neighbor wasn't as lucky:
All this was followed by half an inch of ice:
As the saying goes, if this ain't a mess, "it'll do till the mess gets here".
Note to self, my Wildpeaks didn't impress me very much on the icy roads. I felt like the AWD Subies could run circles around me. Maybe they were just braver, I'm new to snow and ice.
Took her out to explore our new digs in Portland after the crazy wind/snow/ice storm of the last few days....
Ice is no good. Interesting to listen to the tree limbs breaking all around, not interesting to be up on the roof at 3am cutting those limbs that are resting on the house threatening to take out the powerlines.
Back in the day we used to do donuts in empty parking lots in the snow. Good practice as long as no curbs or other detritus got in the way and we didn't get too donutty and fall over.
The subie tires have more sipes for grip, and lower profile for more stability on those unexpected slides. Coupled with experience that you don't have yet, that's the circles around you. The downside of going faster in snow and ice is the part where you have to stop. Around here that's the part that gets 'em.
And who'd want to down the road doing circles anyway?
[MENTION=636945]Spiker Engineering[/MENTION] your unlucky neighbor was actually lucky. Corners are the best spot for that.
Still sucks!
Status
Cpn2mss
