Yea pleas do. I have this usb charger also. Haven't hooked it up. I wish it had its own independent LED wire.
I have one in mine as well, I ran mine off ot the cigarette lighter wires to the center console. I like that it stays lit up and its easy to find at night. If you just use a quick charge cable with it, phones charge well.
Removed the upright crossbars on my roof rack. Have 9 roof top rails creating a sort of basket base. Working on a low profile rail.
Also painted the wheel caps black.
Installed OME lift w/o spring compressor
June 3 spent 6 hrs in 110 F temps installing front lift kit used a technique I found in Utube where 2 guys installed bilstien 5100 & longer tundra coils in their 2003 taco
Everyone else likes that too ;)
Everything installed. It's not the prettiest or a show car. I can't figure out how to fully cover the hole so you don't see the cut. Because the box behind the plastic cover is a seperate piece. Because I want to be able to remove the trim when needed and not have to unscrew the subwoofer out. So basically I can remove anything like it was and be able to fix if something is broken.
Like I said, the box is beyond small and not even close to right volume. It doesn't really hit on low volume but turned up it hits good. It's single 10" sub.
I have 9 wire running. It's basically 1 wire with 9 individual wires. So I can tap into all the speaker wires and just hook them up to my 5 channel amp. This eliminates me from running seperate wires to speakers. And leaves me with 1 wire which sends power to the sun from ignition.
Awhile back I picked up a bumper off of Craigslist. The guy mentioned that he had just done the tundra upgrade and had pulled off his old brake pads and rotors that only had 1,000 miles on them. He said I could have them for free.
I finally got around to installing them today; they work just like new.
Thanks Craigslist guy!
I was thinking that to. That running it of cigarette outlet would be ok. As long as your just charging a cell phone.
I actually removed my cigarette lighter a while back and had the wires to use. I have my CB and my USB running off of the original wires with no problem. There are times that I have to charge my GoPro with the USB too. I have had no problems with it charging anything so far.
Details...
I was up early to wash, clay bar, compound, polish, and seal the 4Runner in order to try and fix the paint (dog hangs out window and his nails scratch the paint pretty badly). The picture below is after washing and claying, halfway through the compound process; front door has been done and rear hasn't. Before compounding the front door looked just as bad as the rear.
I discovered a crack in my driver side valve cover. Just replaced gaskets on those less than 2 weeks ago :ybrick: Anyone have a driver side valve cover they'd be willing to sell?
Lots of stuff on the horizon. I got my AOR bumper back from being powder coated. When I swap bumpers I will be installing my transmission cooler. I also just placed my group buy order for my SPC LR UCAs. I am starting to gather parts for my lift. Woot!
Oh, and this happened the other day.
REE
