Installed my T4R.ORG decal! :guitar3:
Tried to remove o2 sensor bolts to replace with new and one came off other i got it off looking like this....
anyway replaced with bolt and new nut
then cringed to cut into my grill but turned out well to clear for my new lights .... Yes they are huge, Yes they are bright.:llama: then washed her up and drooled
Got some KO2s E load today. 265/75/16. I have 99 coils in front and 960 back. It rubs on the driver side because the fender is dinged in. I'll probably go to 3" lift soon, and a front bumper.
I spent all morning researching Duratrac Cs vs KO2 Es and was going to order Duratrac Cs but nobody stocks them, every place here only has E load Duratrac and KO2. The KO2s where actually cheaper than the Duratracs Cs so I got those instead. $857 out the door.
I've only drove 20 miles but they seem fine so far. Although they got a lot of pebbles stuck in the tread already, maybe the Duratec is better for gravel? They were aired up to 41 psi. I think I will air them down for gravel and washboard roads around here.
This video sold me on them. https://www.youtube.com/watch?v=Em8oErdIw98
Nice, I think the KO2's have the most attractive sidewall. I'm planning on sticking to ST Maxx's, but might switch to KO2's once I move out to California depending on the terrain I encounter.
Dropped $26 for coolant and added some some to my resovuior.... it was bone dry.... i thought i'd kept better tabs on that
Plugs and wires. NGK all the way around. Total of about 1 hour for everything. I got to have a nice little oh shit moment at the end of it to.
I took a few things off to be able to access the plugs. After putting everything back together I looked it over and everything seemed to be good to go. I get in the rig and turn the key. It runs for 1 second and stalls. Repeat that about three times. WTF? I know the firing order is correct because I wrote it down when removing the wires, double checked it via Google, and the cylinder number is printed on the wire set.
So, I get out and peek into the hood again. Nothing, nothing. That's right, that also looks correct. Hmmm, where's the plug that goes into the MAF? Oh there it is. I plugged that little wire harness back in and the rig fired right up.
I'll be honest though, for a second I felt like a complete moron who'd somehow managed to screw up a spark plug and wire job.:)
Spent about 20 minutes popping a new fuel filter in and fixed door panel prior owner hung in track wrong. Slowly getting things done since buying truck
Replaced the mouse-chewed washer filler neck with a boneyard find that looks new.
P8200462_zps4pfmvpos.jpg~original
easy pull out- push in deal.
Gathered parts for a mod inspired by our TDI jetta wagon and @Chim
P8200536_zpswxgyw0ic.jpg~original
Nabbed a boneyard air box/maf/n'junk from a 99 in case the 96's maf bites the dust. Will be converting to the cheaper style maf if that happens. Right now all is well and good in maf-land.
Could've been worse...
The Country
I wondered about you when you told me never to leave a box of wooden, strike-anywhere matches lying around the house because the mice might get into them and start a fire. But your face was absolutely straight when you twisted the lid down on the round tin where the matches, you said, are always stowed. Who could sleep that night? Who could whisk away the thought of the one unlikely mouse padding along a cold water pipe behind the floral wallpaper gripping a single wooden match between the needles of his teeth? Who could not see him rounding a corner, the blue tip scratching against a rough-hewn beam, the sudden flare, and the creature for one bright, shining moment suddenly thrust ahead of his time— now a fire-starter, now a torchbearer in a forgotten ritual, little brown druid illuminating some ancient night. Who could fail to notice, lit up in the blazing insulation, the tiny looks of wonderment on the faces of his fellow mice, onetime inhabitants of what once was your house in the country?
B.C.
Starting to look like an engine again...
DSC_0119 by Alex Wilson, on Flickr
Valves adjusted, heads on, cams adjusted, exhaust manifolds on, valve cover on, intake manifold set in place. That's where I ended as my finger (cut on spark plug tube) started to bleed through my bandage.
Going to try to wrap this thing up tomorrow and have it driving for Monday!
Here's a better shot of the crack in cylinder 4....
DSC_0104 by Alex Wilson, on Flickr
Are you kinda just winging it with the FSM?
Jeez, I guess we really take autozone for granted.
How much would it be for someone stateside to throw a few coil packs in a box and send them to kitts?
Have you verified that every inch of the harness/wiring from ignitor to coil packs is intact? This almost sounds like a sneaky little short where some insulation got rubbed away exposing a wire.
The Country
B.C.
Alrighty then, book club is in full swing.....[emoji2]
Sent from my SM-G930T using Tapatalk
I showed a friend from Tokyo around West Seattle. Hit some spots to snap a few pictures, and grabbed some fish and chips from Spuds. Mmmmm.
Philthyphilthy
