Status
Not open for further replies.
replaced the bulbs in the climate control unit an the two for the ECT/rear window/rear defrost area
don't even want to tell you how much i paid for OEM bulbs. we get ripped off up here in canada
I picked a set of black plastidipped 94FJ 5Star 16x8 rims with 275/70/16 Geolanders with some tread.
I tried them as is and they seem to fit on my stock 98 limited. Should they fit? I was sure they would rub, but they don't seem to. Is it dangerous? That seems like a pretty wide tire - is it too heavy for stock balljoints?
Cleaned up the 4Runner real good before winter hits. Wash, Clay Bar, and Wax. Took a few pics:
IMG_0861_zpsadwgylxw.jpg~original
IMG_0862_zpsdp6ob7nt.jpg~original
IMG_0863_zpszfhe745x.jpg~original
IMG_0864_zpsy7s8r4dy.jpg~original
IMG_0865_zpsa7k5ke5b.jpg~original
IMG_0860_zpsisrbvofa.jpg~original
IMG_0866_zpsvimzlydv.jpg~original
IMG_0867_zpshksrmwnc.jpg~original
IMG_0868_zps6sykfwli.jpg~original
IMG_0869_zpsxrktzoer.jpg~original
Blinkers/orange led work seperatley obviously. White led works with daylights and headlights. Everything has its own harness. Waterproof.
Total Chaos Spindle Gussets Installation
Finally finished up one of my projects... Installed the Total Chaos Spindle Gussets. Now it's time to press everything back together. For more info, it's in my build.
Very nice mate. Going to do this when I get my new shocks. But I'll be doing it with everything on the vehicle. Not going to press out brand new own bearings and seals.
Drilled a cleaner, bigger hole in my firewall and cleaned up some wiring. All in preparation to wire a subwoofer and some more lights. Pictures and info Here
Did you do anything to reinforce the drivers fender. That extra battery adds a lot of weight and the vibrations can tear the sheet metal.
I did not think about this. Do you have any suggestions on how to do this?
Personally I haven't done this but I've seen it happen.
habanero's 1996 4Runner Build-Up Thread - Page 98 - YotaTech Forums
[MENTION=5345]habanero[/MENTION] how's it holding up?
Sorry for the delayed reply, was out in the woods building new singletrack on the Berryman Trail!
The repair is holding up great after 2 years. Couple of things may have helped keep it happening in the first place (this is speculation on my part)...
1) Having that battery box brace up top to help keep the weight from wiggling.
2) Not pounding on the inner fender to make space to set the battery box further back. Needed to, but don't think I did it any favors!
Though I've seen a couple of posts about the same issue on other trucks. Have not looked into what their theories are.
IMO basically wiggle=eventual trouble. Minimize wiggle.
I do some mild to moderate wheeling which can't help but am thinking it's more the washboard roads that do the most damage. Like the 20+ miles worth on the way to the Maze district. Am much better about airing down for those, especially since OBA. :D
Those look sweet, I'll have to put that on my mod list, maybe when I change out my Lower A-arms next year, the bushings look shot. My spindles are a rusted mess.
Yesterday I changed out the o-ring & gasket on the oil filter housing. Was a pain to get off with my headers in the way. The top two bolts were pretty easy but I stripped the nut underneath. Bolt extractor worked like a charm. Had slow leak there for a while.
While I had the intake off I decided to put on the K&N CAI I had laying around. No CEL & seems to be running fine.
When I change mine out I'll send you my originals if you want. Complete spindles with my original bearings, dust shield an all. Its a lot easier and safer doing the mod off your rig. I have your address. I'll see what the shipping cost is via fed ex. Just let me know. Nice thing is there's zero rust. I don't see any reason for me to keep them. If you want my buddy to weld them on here we can work that out as well.
20161013_182527.jpg20161013_183338.jpg20161016_175552.jpgthis is what I've been doing for a few days. This helped out alot with road noise
Sent from my SM-G900T using Tapatalk
Status
