Added some horsepower. If you any of you live near York, it's worth the stop to sample a "Schweet ale".
Care to share how you did it? Which heaters did you use? Where did you wire them and how difficult was it removing the stock cloth cover?
Obviously not addressed to me, but I installed heaters in my cloth seats about two months ago. Used these, you'll have to order two, since they only come in one pair.
https://www.amazon.com/dp/B002U6IL9...&qid=1486140635&sr=sr-1&keywords=seat+heaters
The install was fairly easy just time consuming, I'd recommend buying a quality pair of hog rings and hog ring plier. The one that came with the kit is pretty bad. If you do those, the install is simple. Remove seats, remove upholstery. and install kit. It took me about 1-2 hours a seat I'd say, and now that I know what I'm doing I could easily do it in an hour tops. Wiring was simple, I connected mine to an add a fuse, and there's a exsisting ground right under the carpet under each seat. PM if you have any questions or want to see pics.
Got it all detailed. The guy spent 8 hours on it. Looks amazing. Acid wash, clay bar, polish, wax. Inside all the usual. Then it rained before I got a picture :-(
Was gunna install my last CVJ axle, but then a co workers wife dropped there 4Runner off so I could re booot there leaking CV. Ended up spending 8 hours fixing broken shit. Ended up with 1 new wheel bearing, 2 new axles, 2 new brake calipers, front diff seals, fluid and rear diff/transfer case oil. Also all 8 skip plate bolt holes drilled and re taped. Following other mechanics shitty works sucks.
JET 69144 98-05 Toyota Tundra Sequoia 4.7L V8 JET Power-Flow Mass Air Sensor
Anybody have any experience with the JET Mass Air flow sensor?
The write up below sounds to good to be true....and I'm pretty sure it is to good to be true.
"The JET Powr-Flo Mass Air Sensor delivers improved horsepower, torque and mileage from your car, truck or SUV by simply replacing the restrictive stock mass air sensor. The factory sensor not only is a major restrictive point in stock intake systems, but it also limits the full potential of aftermarket cold air intake systems. The flow bench tested design of the JET Mass Air Sensor provides airflow increases of up to 45% and installs in 10 minutes or less. Compatible with other aftermarket upgrades such as computer upgrades, cold air intakes, TBI spacers, free flow exhaust systems, etc."
I have seen it priced from $150-$200.
Ready to bolt up now when I get the time. I don't think I'll take the time to polish the added pipes. Made some aip block offs to go in too since I already bypassed the pump.
First mod on my new to me 08. Tinted front windows. 20% tint. Matches pretty well. I am happy with how it turned out.
Sent from my SM-G900V using Tapatalk
did half of an led headlight swap. have to pull the headlight or battery to get the drivers side in. output is about the same but the cutoff looks much better. before anyone says anything yes there are better options or colors but i got these from a friend for half the price he paid from diode dynamics. i think the color is the 4k but i also have yellow covers but i think it looks a bit odd in yellow. next is to use my headlight kit on it to clean up the lens
20170204_185638_zpsnjwpv2d4.jpg~original
20170204_190034_zpsn0jqfszz.jpg~original
20170204_192409_zpshqcyeqq8.jpg~original
just wait for these to fail and put the stock halogens back on, pretty sure the stock are brighter than the leds. the leds just give that look, performance wise, it still suck ass.
2001ATL
