Sent from my SM-G981V using Tapatalk
Fixed my front windshield wipers. While driving home in the rain the passenger side just stopped.
Took it apart and found the wiper drive ball joint failed, and would not latch onto its knuckle. So I trimmed some of the plastic away, drilled into the knuckle and then installed a 1/4-20 helicoil. A short bolt some red loctite and a washer done and done.
It should last another couple hundred thousand miles.
Should mention while I had it out I popped the other knuckles and greased everything with fresh moly grease. Moves much smoother now as well.
Does anyone know the size for our plastic grille rivet clips? Broke a few yesterday and the 1/4” 8mm ones I had ready to go were too small.
Replaced my malfunctioning OEM JVC headunit with a newly-released Sony (XAV-AX150) unit while buttoning things up after replacing the evaporator core.
Impressed so far, it’s a lot of screen for the price and has CarPlay/android auto. Seems to be the best of both of the most popular Sony units, they finally moved the USB port to the back. Only thing I miss is an actual knob for volume but steering wheel controls solved that.
Looks great. Did you buy a double-din mounting kit or did it come with one?
If you make one change, you can prevent it from leaking. Flip the retainer around so the bevel faces outboard. See my thread from my FJC.
Cut the old retainer off with a dremmel and cold chissel. Heat the new retainer so it expands and drop it in place. Once it cools, it will seal on the axle. Dont forget the C clip
Rear Axle leak & bearing replacement | Toyota FJ Cruiser Forum
I love this solution. It will be the next one I use when this seal eventually fails. This time, I just tapped the seal in 60% instead of flush to keep the lip riding farther out on the retainer past the bevel. I put a little sealant around the edges as a precaution to just hold it in, though there are no forces really applied to make it come out.
Initially when I bought it, the dealership didn't replace the wheel bearings and seals, they just packed them with heavy grease and sold it to me. 5 weeks later I had huge, goopy leaks, but I was across the country and only had a 1 month warranty.
2001ATL
