Started my satoshi...with an added twist.
IMG_20130620_194535_479.jpg~original
What did I do today??
My woman and I went to the beach for our anniversary. Epic berms and dunes.
Then went to have some lunch.
Then we went to a local car show, and we saw a cool little trail rig
And of course his towing rig
And lastly, my turn signals FINALLY showed up!
Awesome, this will work! Now if I can just paint the grill without getting runs/drips?!?!
It's easier if you remove it then clean it up. Also use a primer it helps out alot..
IMG_20130531_120531_096.jpg~original
end results..
IMG_20130602_191334_991.jpg~original
Just did my roof rack yesterday as a matter of fact.. :dance:
Before..
IMG_20130602_191354_507.jpg~original
IMG_20130620_111136_206.jpg~original
Prepp and prime..
IMG_20130620_115701_593.jpg~original
IMG_20130620_111049_841.jpg~original
after...
IMG_20130620_130127_754.jpg~original
IMG_20130620_161238_426.jpg~original
and removed my running boards... again:sad:
IMG_20130620_150354_062.jpg~original
and pics of my fishing rod holder as promised.. I used a hanger from walmart and a 1 foot piece of PVC. Cut 2 inch rings and a bungee cord and wala!! Not the fanciest but works great:clap2:
from inside..
IMG_20130620_150251_826.jpg~original
IMG_20130620_150230_152.jpg~original
from outside..
IMG_20130620_150315_481.jpg~original
Great work 28., looks awesome! My next project will be the roof rack and silver panels front and rear. I am apprehensive about taking the roof rack off however due to potential leaking. Did you use any sort of silicone or sealant when you reinstalled the rack?
No i just tightened them down. Only way I could see them leaking is if you were to leave the bolts VERY loose. So far I've painted everything that was silver on mine with metallic black. I can't strss enough to use a spray on bonding primer. Makes the job ALOT easier and just holds up much better. Apply a couple of coats letting each coat dry before aplying the next one. NEVER try to completely cover the object your painting with one coat. Paint will run for sure. I applied 2 coats of primer and about 4 coats of paint on mine..
I would post some good shots of your work to help let people see what kind of fit and finish you have on yours.
goddesszilla
