null_zpsb9dfb180.jpg~original
null_zps13a80bb2.jpg~original
null_zps87fa2a0f.jpg~original
The CBI fits perfectly and doesn't touch the body when flexing. What a great product.
Got my idler pulleys replaced for the second time under warranty. I just cant stay out of the mud haha. So i got bored at work and this was the result
Nice, expensive :eyebrows:, choices. Ha. At least you'll knock it all out in one purchase rather than buying and "upgrading" later on like most of us here, including myself. I'm curious to see how much rubbing you're going to have with the 305s and the -10mm offset of the Stealth 6s. Either way, it'll look awesome.
Hopefully not to much. If the rubbing is too bad I may go down to 285's
anyone know if i can buy a hilux surf drivers door switch panel and wire it in to drivers door switches to have them on both sides?
also does anyone have a part number for it?
these lights look like the drop in projector headlights i recently pulled the trigger on....about $200 or so...looks nice!
cheap ass man's version of a proper retro...........haha :bigok:
I have them and like them. I'm gonna black out the fogs and turn signals eventually too. Alex, have a write up or tips for that?
I only did the fogs and turn signals
Heat in oven at 250 for 10 mins. Pry apart with a flat head. Scuff reflector with sand paper. Paint with spray paint for plastic. Put back together, press together, bake for 10 minutes, and squeeze em back together all the way.
Do not heat them in the oven for 10 minutes. Preheat the oven to 250 then turn it off and put them in for 10 minutes. If you leave the oven on and put them in you risk melting the lens and housings. You just want it to be hot enough to make adhesive loosen up.
I'd recommend doing them at the same time cuz it's super easy to get the fogs and turns out when the headlamps are out.
I do 200 for 10 minutes and it's always worked well.
I like a little more heat to help the lens separate a bit better/easier.
I put the lights on a piece of cardboard to prevent melting the light with the wire rack
Jesse1
