Made it up Mt. Baldy and had a blast!
Really stuffed the rear tire in this and Mt. Baldy mine in the top of this picture
Flexing the rear and in the background is the town of Breckenridge and all the ski runs in the mountains.
It was the ladies first time and she loved it. Maybe after vacay I'll finally start my build thread and put more hi-res photos up! Cheers!
Sent from my iPhone using Tapatalk 2
Ooohh I like CTS-V's
You sure get a lot for your money with Caddy's. It's probably the only domestic I would consider buying. However, there's no convertible. I went with a BMW 135i 'vert for my daily driver.
Edit: Wow, $60K to start for a CTS-V. That's a lot of cheddar.
Interior deep clean mod:
CAM00099.jpg~original
CAM00100.jpg~original
CAM00101.jpg~original
CAM00102.jpg~original
Using a carpet cleaner i get locally and a Bissel Green Machine. Also using interior brush to scrub. usually use ruff stuff, any suggestions for really good carpet cleaner
This. I need to do this.
[MENTION=80027]Nathana92[/MENTION] - where are these snorkel install photos!! :bigok:
I use Unbelievable Carpet & Stain Remover
Core Products Company - Unbelievable!® Stain Remover
I work in flooring and have used this so many times with customer service calls and in my detailing. I've diluted it to go with my Green Machine as well, worked awesome. Great product, I highly recommend if you can find it.
Drove to work and found some clunking/rattling noise in the rear of my truck whenever I close the door. Anybody have some ideas what to check? I already have scheduled maintenance at Toyota tomorrow for my timing belt
check your spare tightness
I realized I stripped the Trans drain plug last time, it came out hard yesterday. Ugh, the 3 quarts just drained out...local dealer did not have any in stock. Should have stopped and tightened it back up when it felt funny unscrewing.
Anyway, luckily I had the right tap, the pan threads were pretty good actually, new drain plug today and its all set now.
That was a panicked moment or two yesterday...
Not today, but all recently:
-Replaced front endlinks and reinstalled my sway.
-Replaced passenger side CV axle (twice)
-Alignment
-Installed diff drop (yes, I had reason too. haha)
To do list:
-interior deep clean
-wash and wax
-redo my wheels
-color match my grille to my wheels.
Got my timing belt and other 100k maintenance done. Talked the stealership down by $400 too. Felt pretty proud of myself and the amount of information I've learned on here
The install is going to be a bit more intensive than anticipated when I said I was going to "install it tomorrow"...it's not something I want to rush or half ass. I'll mess with it around the end of august, maybe sooner if I have some time off.
Readjusted my headlights, found a nice flat space and did the lower cutoff line at 3 inches drop from my stock height of 37.5 inches, hopefully this should be the best for me to have my color flicker at the mirrors more. I had my lights at a 2.5 inch drop before and it was a little on the high side. 3 inch drop at 25 ft is the best option for us trucks with real hid projector retrofit.
patnewton
