Swapped out a CV axle on the passenger side this morning. Over the past couple months I have:
-Swapped in Leather Seats
-Added Pioneer 4100NEX and Rear Monitors
-Changed Spark Plugs
-Changed Oil
-Changed Transmission Fluid
-Flushed Radiator
-Tacoma Shock Swap
-Zero Calibration
-Changed CV Axle
-Added tube style OEM roof rack
Outside of the plugs, rack oil and stereo, I had never done any of this stuff, but the DIY write-ups on here are confidence inspiring.
Rested on the 7th day.
Because GOD said it was good!
didnt do much with the truck but i did drive it to my local msf class and now have a class m license. got to ride a little wr200. will be great to be able to bring a bike to the trails
20150614_122000_zpswdku7lds.jpg~original
Just picked up a new set of wheels. MB 352 16x8.5 et-12 4.5 BS. I tested one wheel out and had no issues with the brakes. Just a little concerned about clearance (ucas mostly) when the duratracs go on. What does everyone think? I would certainly appreciate some feedback!! Thanks! Full OME 3/2 the 19th.
I ran 4.5'' backspacing with more aggressive 285s. I never hit my stock UCA.
apply my left over sheets(4.5) of second skin damplifier pro on the rear floor and halfway under the back seat, will test if it quiet down the noise from the muffler in that area. also a fresh mobil 1 extended oil change, i wonder if i should start doing those at 15k vs 10k im doing.
Passed by [MENTION=46025]HokieRunner[/MENTION] on my way to the Tough Mudder in VA on Saturday, then called up White Knuckle and ordered some rock sliders :D Can't wait to get those things on but they won't get here for 4-5 weeks.
Just installed K&N air filter and I can't believe how different the truck sounds now. It's a great combo with my Gibson catback system.
Here's a reminder for people who live anywhere that rust is an issue. Replace your license plate bolts with stainless, plastic, or something that won't rust into place.
I've had my 08 4runner since August (about a year) and I bought that vehicle because it was fairly rust free for being in the midwest. I have changed the plate a few times since buying so I had no issues. That was summer. This winter apparently did some damage.
My in-laws bought me a license plate holder for christmas so I finally got around to putting it on this weekend. One of the bolts came out fine but the other snapped off at the head. F***.
I soaked it in PB blaster to try and loosen the bolt, drilled it out, then tried using an extractor to remove it. I ended up snapping the extractor where it contacted the bolt. Double F***
I came back to it a few days later (after letting my frustration die down) and tried grinding it down and removing it. Good luck trying to drill into a piece of tool. I decided to try removing the internal panel for the hatch. That was easy.
After getting the plastic vapor barrier put aside, and what a messy piece of plastic, I realized I could have used vise grips to remove the bolt from the inside. Since I had drilled it out initially, it snapped as soon as I tried to turn it. Triple F***.
I eventually tried everything and it came down to trying to remove the threaded square nut from the hatch all together. It was tacked on in the corners with some very tiny welds. I ground those down with a dremel and it started to come off clean. Then one of the welds decided to hang on a little too long. Quadruple F***.
Outside of the "good" threaded nut. Getting rusty.
Inside of the "good" threaded nut.
Outside of the removed nut.
Inside of the removed nut.
I used a bolt/nut to secure the plate for now, but I'm hoping to have a permanent fix done once it stops raining. Now I know how my dad felt when he shut my fingers in a car door when I was little. I felt so bad for hurting the poor girl.
OH, and I put on some RainX wiper blades to replace my 3 month old Trico blades. What a difference. I think I'll buy these RainX blades from now on.
I used a bolt/nut to secure the plate for now, but I'm hoping to have a permanent fix done once it stops raining. Now I know how my dad felt when he shut my fingers in a car door. I felt so bad for hurting the poor girl.
Whoa, a tough one.
Who would have thought just putting on a lic plate holder would lead to all that.
Thanks, I'll check mine.
H.Sikina
