Drove through most of Oregon for my buddies engagement party. I've got something going on with my trans. Might the the "rumble strip" deal. I'll have to wade through that thread and get a trans service scheduled.
Got the new tail lights installed, I'm not used to them yet, but I like the different look. I didn't end up needing to remove the upper trim panels, I was able to get to both bolts no problem. Here's a few pics:
Side by side with stock
20150822_151101_zpsrhr62jmn.jpg~original
First one installed
20150822_151855_zps5y9zmvde.jpg~original
Old vs new
20150822_151918_zpsypy3amko.jpg~original
Had to check out how the LED's in the clear compared to stock
20150822_152134_zpszjbqhkbr.jpg~original
All done!
20150822_161656_zpshbimofmp.jpg~original
Washed the truck and took some afters
20150822_162029_zps2sxx9giu.jpg~original
20150823_155913_zpse7lbyohm.jpg~original
20150823_155919-1_zpsbzpcauks.jpg~original
I'm liking them so far, they match my blacked out headlights well, speaking of clean truck.
20150823_155938_zpskmbla4up.jpg~original
20150823_155942_zpssub1quad.jpg~original
Look really nice with your color truck. I was debating on getting some of the 06-09 stock tail lights or the ones like you just installed. Where did you order yours from?
Thanks Morris, the whole reason I went for the black was because it compliments the Shadow Mica really well. I'm happy with them, I ordered them on Amazon
How hard was it to replace the door handles? Did you get them painted to match?
Fronts are relatively easy, can be swapped by using the rubber grommet on the side of the door. Rear needs the door panel, and door lock actuator to be remover in order to gain access.
Didn't want to bother with paint, just bought them all new, painted. Still waiting to find a OEM spoiler used, too rich for my blood to buy new.
image by Kevin Mayne, on Flickr
Got new tires, will post pics once stupid Photobucket decides it wants to play. BFG Mud T/A KM 255/75/17, moved the front liners forward, and removed front flaps and trimmed the rears flush. (I posted about the flaps already) The best part of this is it all cost me $550 out the door. Finally got it work.
e6ae7a0d-a5dc-4603-bbfa-5e0cfbbf4827.jpg~original
b84c304b-29ff-49ce-a9a9-5e7dde47d58e.jpg~original
8c0e84f1-ea05-466e-a47b-fbd916ed00e1.jpg~original
Looks good! Do you have wheel spacers? I have the same wheel and tire combo and yours look a bit different to me.
Get to order new parts tomorrow! All the bushings in the front end are SHOT! I literally have inches of play... So, since I don't want to screw around with bushings and ball joints I'm ordering brand new lca's, tie rod ends, cam bolts, and new ball joints for the spc light racing uca's I bought off Ark here. I'm also buying some super bump stops from wheelers for the front. Buying stock replacement lowers. Found a whole set on eBay pretty cheap. Also going to do some painting for the upcoming winter while everything is apart. I also have a couple solenoids going bad in the transmission. I bought some used ones and I'm going to be swapping those out and putting a clean filter in. Will post pics when I do everything.
I still need to fix my leaking manifolds, DESPERATELY!... Soon I hope...
Ordered a roof rack. I gave in and ordered a Gobi even though I really wanted a Winston works for the price. Hate to support Gobi because of all the lawsuits against little companies but in the end, I don't want to wait any longer for a rack.
So the stealth rack and some rigid E2s will be in my garage for when I redeploy in October. Lots of Arizona camping to do this winter.
Pulled off the hideous chrome SR5 grill, hatch panel, and door handles... Finally. Sanded and cleared the headlights while I was at it. Still might swap them out for the darker sport headlights.
Where did you find a pre-painted grill?
Rockauto has some black plastic grills for $90, but you do have to paint them. If there were a place that sold the pre-painted grills for a reasonable price I'd go that route...
Thanks for your time. Nice pictures BTW. Your 4runner looks nice and sleek.
Good call with new LCAs and hardware. I replaced mine because they were frozen.
Why do you think you have transmission solenoids going? What's the mileage/service history of it?
One day it started acting up, not shifting then slamming into gear. Acted like the fluid was low. I went to autozone and had codes scanned, said 2 solenoids were bad. It is shifting fine now, but I get a surging sensation that is caused by the solenoid not opening correctly. Feels like I'm constantly hitting the throttle and letting off as I accelerate. Stopped at a transmission shop and they explained that when the solenoid goes bad and you are driving it doesn't keep constant pressure, it fluctuates which causes the surging feeling. Transmission ships almost never work on these transmissions though and they don't rebuild them, they replace them. $3500-5500 for a remanned Trans. I bought used solenoids from a junk yard for $120. Drop pan, replace, new filter and fluid, should be good to go.
