Did some more painting today. You can't really see the difference in the pictures though.... Also discovered how cool it looks without running board!
Cleaned and waxed my car, test my new lights out, called toytec and asked how much longer my front coilovers were going to be back ordered. Called dealership to get a quote on a transmission drain and fill, they responded with they only do flushes? Then made my 4runner official and slapped on some T4R.Org stickers. All in all a very busy 4runner day
Probably because that means they need to waste/bill 12 bottles of fluid instead of just using the proper amount.
LCA skids arrived and painted, drying now
New front sway bar bushings from energy suspension
New rear sway bar links and bushings from energy suspension
Reverse camera showed up
My pineapple grenade shifter came back from being repaired
Lots of stuff to install!!
lots of goodies you got there.. i was wondering how your magnaflow exhaust with the resonator removed sounds on your v6, i also have the v6 and eventually am planning on doing the exhaust..
Found this in the floor of my truck. Is this a Toyota part?
Not quite sure, but, might be broken on the side. Look at where your seats bolt down, might be the cover piece.
You might add a picture of the underside and what section of the floor, front, back.
So I was playing with my reverse lights today and couldn't decide on a color nor the type of LED's. Are projection LED's really that much better than the normal ones without the lens?
Does that go behind the door pull? Kinda looks like it
If your referring to the hatchback strap cover, no, it's rectangular and flat.
His picture shows a curve to it, and it's not wide enough for the seat bolt down on the front or back bolt section.
I don't think it is a part for his toy, I'm not seeing anything that it could be from.
