anyone ever address a rattle in the front dash area i cant even describe it lol i guess the best i could say is like a plastic crack in something poping or clicking together. I haven't even been able to pin point it. when im in the driver seat it sounds like its coming from the passenger side A pillar and when i lean over the sound changes dirrections and sounds like its coming from just above the rear view mirror lol I've pushed and hit and knocked on everything and cant find the cause.
Felt guilty for running her dry the other day. Filled to the brim with shell v-power today. First time I have used premium in my truck in about 2 years. It likes the octane!
Steering u joint needs to be tightened? Check the shaft.
Took out my HCF by drilling the rivets. Only managed to crack the frame of the filter in one place before taking it out lol. So far just from starting her up after the removal, I've noticed a smoother (in a way) start. The rpm's did not rise slightly then fall to normal like they did before.
I'll have it on the road tomorrow on the way to school to see if I can feel/hear any difference.
removed the hcf filter and noticed almost no sulfur smell heading up the hill to magalia
Took the blower motor apart and cleaned it, was making a loud ticking sound at all speeds. it was covered in a thick crusty black carbon soot from the brushes surprised it was still working! used CRC Lectra-Motive Electric Parts Cleaner and it worked great! oiled the the end bearings too. quiet as a mouse no more ticking!
photo2_zpsc170897b.jpg~original
In Nebraska for the first time..pretty boring.. off to colorado tomorrow to cap of my 4 day 1800 mile road trip
<a href="http://s1196.photobucket.com/user/hockey2319/media/photo4-4.jpg.html" target="_blank"><img src="http://i1196.photobucket.com/albums/aa415/hockey2319/photo4-4.jpg" border="0" alt=" photo photo4-4.jpg"/></a>
Was that motor easy to take out? Mine is pretty annoying, I was curious how to get rid of the noise, thanks! Any guidance is appreciated!
Nice pic
Damn, I almost forgot how ugly the stock orange was, guess I'm finally used to the blue
I was really easy three screws hold it up under the dash.
under the glove box there is a cover that protects all the stuff under the dash held on by one phillips head screw, loosen that and pop the cover down there is three snap clips at the top then let it hang on the floor
you will see the blower box and the blower motor hanging out the bottom
loosen the three screws (flat head, torx bit, or 8mm socket works best)
unclip the wire harness from the motor (push tab and pull type)
motor drops out!
the fan part is plastic and is pressed on the shaft of the motor. take the shaft clip off with pliers, pry the little tab back and put a large flat screw driver under the fan gently prying up evenly on all sides of the fan.
until there is a gap for your fingers then have a second set of hands slowly pull the fan off while you hold the motor base.
I couldnt remove the motor fully from the plastic base but i removed the 2 screws from the back of the base and sprayed electric motor cleaner through it all. and used a dropper to oil the bearing. Top bearing is cover by a metal cap that just prys off the top of the motor.
remove the brass clips and springs pull the brushes out and inspect to see if there is some even left. my brushes has very sharp vertical edges worn into them that were catching on the shaft making the ticking noise, i just ever so slighty rounded them so the wouldnt catch on the shaft and tick
not sure if they can be replaced. I had about half left.
leolediola
