Installed a comet rs 730 antenna mount on my hood and ran the coax cable through to the center console ash tray. Now if only the actual antenna would show up...
IMG_20140708_151325_zpsd50r1g7e.jpg~original
Replaced the hood scoop with a factory replacement part. Comes with the studs installed, and correct paint color.
The original owner had left the truck in the rain a lot and water had apparently puddled under the scoop, trickling down the front two studs and rusting them and the nuts into a solid mass. Was leaving rust streaks on the intake cover. Was terrified that the studs would have to be Dremel cutoff removed after they unscrewed from the hood, but copious amounts of Breakfree and grabbing the top of the stud with vice grips got things turning.
Just me, but I cannot tolerate that sort of neglect. Old scoop was badly faded as well.
Studs_zps0b316e0d.jpg~original
Scoops_zpsc364f17e.jpg~original
Anyone wants the old scoop for whatever, it is yours for the postage.
Finished back up camera install and plasti-dipped the faded black portion of the rear bumper. Looks good! :frog:
How hard would you say the install was as far asthe wiring for the back up camera? Assuming you installed it near the rear hatch. Just seems like it could be a pain to me. Have mine sitting there for a couple weeks now but am hesitant to install it myself.
It was not terribly difficult but tedious and time consuming. There is a video that helps you with wire routing and and selecting the correct power source (reverse light wire). Check out the video links below.
Part 1
https://www.youtube.com/watch?v=LBzoD97BcHQ
Parts 2
https://www.youtube.com/watch?v=Y4owoUL8UDo
Got my welder all set up so i can finally get my dual battery box fitted and picked up an ARB 2500 awning. Going to need to fab some mounts for that too!
took it to local dealership. Only to sell my other car, also bought brake pads for the front. Otherwise its been quite solid.
Got my bi-xenon retro almost finished. Baked the headlights and put them back together. Did a before and after side by side with the sexy new projectors
IMG_20140708_224106_zpsbnh6kf9v.jpg~original
The finished product
IMG_20140708_224143_zpseqndxioy.jpg~original
The finished high beam plugs
IMG_20140708_224348_zps7mamri37.jpg~original
What's still left to play with.
IMG_20140708_225232_zps3q3unx4d.jpg~original
Can't wait to slap these on with my new bumper :tongue:
How long did that take you to do the install from when you pulled the headlights to when you put em back together? I'm gonna try to do mine Friday morning before work in the afternoon
If you've already had your headlights apart, it shouldn't be too bad. I've been taking my time and not rushing anything, but I'm also using my existing ballasts that are already wired up with a relay, so they really are just going to be plug and play. I plan to finish up the bulbs/grommets tonight thanks to [MENTION=50591]gaterose[/MENTION] answering my couple silly questions. I will have more pics and a better writeup done by Friday to add to his writeup, so it's definitely doable. You still have my number if you need to text questions?
replaced my windshield. had two big cracks carnage from freeway rocks.
now i need to get the tint brow replaced.
I think I still have your number.
I've had em apart before. It should just be a bolt in type deal for me. I have everything else set up
Shock upgrade and new axles. Should have taken a day but ended up taking a couple, seized shock bolt did not help matters.
