Took it to the spray bay and hosed it down, followed up with a dry and Turtle Wax spray detailer (great stuff). Came out nice.
Won't stay clean for long but it was nice to see it blue instead of gray again.
Put a pet cover on the rear seat
Greased the front driveshaft (missed that last time somehow)
Changed diffs/transfer case fluid
Checked single bolt tightness on steering column in cab
Slid steering shaft coupler up slightly
Found some bolts from the suspension install needed to be retorqued
Steering now feels tighter and got rid of clunks from the upper strut mounts.
Oil change, tires rotated and spark plugs changed (122k miles)
Just have the t-case to drain and fill and all fluids are fresh :)
Looks great!
What tires are those Sporin?
I like 'em.
Can't tell if you're stock height or not...but it looks great.
Stock sized General Grabber at2's... put them on at the start of winter when it became clear that the nearly-new Uniroyal Laredos the truck came with weren't going to cut it.
I'm extremely happy with them over a very sloppy winter. So far Mud Season hasn't been an issue either. They aren't overly loud on clear dry roads either.
Went with OEM Denso. Toyota PN 90919-01235/Denso PN K20HR-U11. Although I usually go with NGK Irridiums, this time I could not justify paying 10-15 dollars each plug, found a deal on Ebay for 6 OEM plugs for 21.96 w/ free shipping. Just a side note when I checked the gaps 4 of the 6 were a bit too much @ .046, its best to be at .040-.043.
If your 4runner is equipped with the V8. 90919-01210 these are Denso Irridium OEM plugs
I put the OEM running boards back on. I tried having no running boards for a month and it was . . .weird somehow. Oh well, it's only like 20 minutes to change them out if I change my mind again.
Also, I took Athena to get cat food. She was thrilled.
Philthyphilthy
