Just replaced front brakes...Napa Premium pads and rotors...also changed the oil...used Mobil 1 and OEM oil filter, air filter was dirty so I'm gonna order an OEM on Amazon
Little road trip to meet some family at a state park, then some preventative maintenance. Rotate tires, oil change, diff oil change.
New ome 884's with camburg uca's!!
Alignment tomorrow..:lasercannon:
Props to @havingfun for the 884 install.
Props to @arkswamprider for the suspension knowledge.
I ran Fins n Things in Moab with my buddy and his rubicon!!!
His next rig will be a T4R!!! He was running 35" tires, front and rear lockers, no sway bars, and aired down. I locked my center diff, didn't air down and kept up on all but 2 A/B lines. One of them is pictured below. The A line is the one with the big ass drop and the B line is the line that was steep as, rhymes with duck! A full size Chevy Silverado we passed just before this section, got stuck (hit body panel) after my T4R cleans the same line!!!
The final 3 pics are me and my T4R stuffed and flexed at the bottom of the B line!
Got my BFG A/T KO2's mounted...they're sweet. They're almost silent and so smooth riding. I went with 275/70r18.
I went back and forth on aligning them with the top of the bumper or the sides I did the sides because and moved them toward center because I didn't want any gaps and the bumper really curves toward the sides.
Good enough!
Waxed most paint under the hood - including underside of it.
Used 303 on any visible/reachable plastic.
Used Meguires Back to Black on any visible/reachable rubber.
Cleaned under the engine cover and washed/waxed it, too.
Good enough!
What did you use on the engine?
Good enough!
It's beautiful
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Replaced the POS Energy front SB bushings and brackets. They only lasted 6 months.
I went back to OEM.
Here are the POS bushings.
And here is the new toy I got to use. 700 ft/lb tighten and 1200 ft/lb loosen torque!!
Well in looking at some good steps for my rig, I asked the seller about the steps( on Facebook) only to notice in his pictures my 4runner! So this is thr original owner of my ride, oh the questions I have, I asked about the steps then nicely asked about my ride, no response for either... brain immediately goes to bad reasons he won't answer.....Damn
delislerebecca
