Do the coil packs have a replacement interval?
I know it's apples/oranges but I just replaced them in my N54 and it runs a lot better.
I can't say for sure but if I remember correctly they are the standard 10mm bolt that is used throughout various parts of the body. Pull one off the fender under the hood and see if it threads in.
I tried several to no avail. Could have sworn they were bigger though. Eh, I could be mistaken. It's been over a year now.
Something like this might be helpful to have around for these situations.
I will be investing in this. Thank you sir!
Well, I replaced the spark plugs, which were quite old. The previous owner didn't have spark plug replacements listed on his log so not sure when the last change was.
Then, I made a second attempt at replacing the upstream air/fuel sensors; this time through the wheel well. Turns out it's ridiculous no matter which way you go and I could not get an angle or leverage from any direction. I gave up on that job.
The brake caliper looked gross, so I cleaned and greased it. Hopefully it's not frozen again
I just replaced my O2 sensor (driver side) and I found it easier to jack up the truck and hit it from there. I also used a 3/4" 18" ratcheting breaker bar. A couple of 1/4 turns later I was able to unscrew the sensor by hand. Good luck.
Did you go from underneath, wheel, or top?
Seem's like I might need a longer breaker bar then. My 12" bar isn't helping much.
EDIT: Nevermind, saw your post in the other thread. You went from underneath. Thanks!
Got a pic of the emblem on my grill set up as my HU wallpaper. Looks better in person; the color inside the letters is washed out in this image.
IMG_4141_zpsjzoeberu.jpg~original
Also, get a longer breaker bar. The 18" bar I used worked great and I think a longer bar would have been better but they didn't have any longer bars that were Ratcheting.
New User
So this is my first time on this forum. Can anybody tell me how to create a post where people can answer back? I tried to make one but it told me I wasn't allowed to. Thanks!
It doesn't seem like 3/8 24" breaker bars are common. I don't think I could fit a 1/2 24" bar with a 1/2 to 3/8 adapter because there's not really enough room. I might go to HF and pick up the same 18" one you have
Gosh, you quoted the wrong guy on your 7,000th post [MENTION=165]momo.75[/MENTION] :p
[MENTION=140803]T4RBoi123[/MENTION]
Ambrose67
