Today I adjusted my ride height on my newly installed CO's that I put on yesterday. May build my rear sway bar links today as well.
Pretty. And no that's not my pack and play. did the work at my buddies house.
New upper balljoints warrantied from spc as well as new inner and outer tie rods. Old ones were totally trashed! Drivers side was so loose it was scary... Alignment tomorrow.
Sent from the drivers seat of my 05 4runner.
Been a big fan of [MENTION=102068]Ryan04[/MENTION]'s bumper, finally getting a chance to start building mine.
Sent from my SM-G900V using Tapatalk
Looking good! i have always thought about putting a light bar there as well and now i am really considering it..
where you able to attach a skid plate under as well?
When all said and done I will. Had a change in plan on how to mount the lower tubing to the motor cross member. I want to be capable of unbolting it for powder coating.
what did you use on the headlights? thanks:llama:
Wet sanded with 1000, 2000, meguiars, Polish, wax. The meguiars is a diminishing compound so it starts as a fine cutting compound the turns into a rouge polish.
Here's a before:
Did this switch panel. Didn't come out exactly as I thought. Might use a different switch later. Works well for now. I still need to label, hide wires, and touch up just a little.
New tie rods (had to cut both of them to get the old boots off), rear sway bar links and bushings (links snapped in half, ball joint studs had to be cut). Good thing for the angle grinder!
No more clunks from the front or squeaking from the back! Whole truck runs noticeable tighter. Got the "sport" back in sport edition. Sorta.
Interesting day so far.... Stupid alignment shop tried telling me they could only get 1.1* of caster and everything was in spec. I called bullshit, especially since I have the balljoints set at the 4* setting already! Left there and am now struggling to find a shop with an opening...
Guy said it's in spec, yet it pulls all over the road, pulls to the right when hitting the gas, to the left when hitting brakes, and is visually toe'd out.... Wtf man.
Decided to Plasti Dip the badges on the weekend
Drove my T4R to work today and sat in her during my lunch break to read the new issue of 4WD Toyota Owner. Life is good even at work. :pop2:
Good luck with that! Had a similar situation with both my Sequoia and my hubby's Tundra. After several tries elsewhere we ended up having the dealer do both. It was quite a headache. Hope you get it straightened out.
On vacation last week, we shared a boat ride with a silver Taco over to the South Core Banks of the beautiful Cape Lookout National Seashore. I plan to post a thread about the awesome experience we had with beach driving when I get a chance.
IMG_4636_zpsrgg1zc4w.jpg~original
IMG_4639_zpstein2zz5.jpg~original
ghengiskhan
