installed leds in my bike rack.
20161112_005931_zpsu9hjozlz.jpg~original
20160630_203558_zpsa0hzibbu.jpg~original
Moving all over? Wheels/tires/lift? Wife and I are thinking about upgrading her to one as well.
I'll be selling those and starting over. At least for the near future, I'll just do a leveling kit on the front and AT tires, most likely factory size. The setup on my 03 is overkill, 95% of my driving is on road, and the rest is easily done in stock form (especially with the rear locker in the Trail).
Been awhile since Ive been on here, but finally got around to gusseting my spindles and installing my new +4.5 shafts from CVJ. Really impressed with the quality of the shafts, and so stoked to have 4wd back again.
IMG_0595-1_zps5vrny5w8.jpg~original
IMG_0599_zpsryb8mx4c.png~original
IMG_0597_zpsfc8f4ey8.jpg~original
How awkward would it be of me to come and just hug your truck? haha :zoom:
Warped angle or are your wheels toed ass out
Went out for a little drive today.
Also made a build thread! That took a while -_-
Sent from my SM-N920T using Tapatalk
Oil change and tire rotation. Wash all the wheels during the rotation. Got rid of a lot of brake dust. Inspect the brake pads and will order some soon. Grease half the zerks since I ran out of grease. Will continue when I get more.
Got bae looking sassy AF!!!
Ordered some replacement HIDS in 6000k CRYSTAL WHITE and they sent me 12000k in VIOLET, that's PTL for ya in a nutshell eventually I will just use these headlights as a foundation for retrofits
they look ridiculous
Philips 194 LED bulbs in the map lights (Vision LED Interior/ Exterior lighting 127996000KB2 | Philips) - Pretty bright. I've used these same LEDs for license plate lights. Philips specs them as 6000k but they're more white than blue, which I prefer. They also run cooler (temperature wise not color) than the incandescent and VLED LED bulbs. I willl be installing these in the door lights and license plate lights next.
Philips 30mm LED festoon bulbs in the dome lights (Vision LED Interior lighting 128006000KB1 | Philips) - Slightly brighter than the original bulbs but perfect color match to the 194 LEDs. I wouldn't recommend these if you want super bright light-up-the-whole-interior dome lights, but I'm satisfied with them.
Just finished sound deadening. By the looks of it, I will not be doing the floor any time soon because I don't have the balls to gut and tear up the interior. I decided to go over all the wiring bc I was losing daylight and it looks cleaner, just fed the switch wires through. It looks better than this pic, it was just in the middle of the process.
Don't know a difference yet, but I will tomorrow when I blast my hoodlum tunes \m/
Edit: yes my tint is screwed up leave me alone [emoji24]
yes thats rediculous.
https://www.theretrofitsource.com/c...ation-specific/morimoto-retroquik-spec-d.html
that may work , im not 100% sure, but if you can find a used headlight to test, thats a better solution.
thats going to be a pain in the butt trying to disconnect the harness for the tweeter, but itll be fine if you plan to run fresh speaker wire. did you do both inner door skin too? i dont think the floors need to be deaden, but i did use some secondskin damplifier pro in the rear floor, havent done the front floor, but really want to do the roof.
