my fiancée has been painting my frame with Chassis Saver and rustoleum rust performer for the hard to reach spots.
Quick oil change again with the fumoto valve. While draining I greased the zerks which seemed long overdue. I don't remember ever putting in that much grease and seeing the axle shaft push back with each pump? Is that normal?
Sent from my SM-G935V using Tapatalk
Plan on doing this with fluid film and a nice degreaser prior in the up and coming weeks. Yours look great!
Replacing lower control arms/sway bar bushings and end links. It's time to freshing up the 2003 V8 2WD suspnsion at 190K miles. Just recently upgraded with some UCAs with 285's.
With the ROSEN AV7900 I got a few years back, I want to have iphone connectivity with the monitors. Bought the connectors/adaptors/whatnot, but completely forgot that the iphone digital signal has to be converted to analog (RCA plugs). So I physically connected them, but neglected the type of signal being transmitted. Stupid me. Anyway, bought these 2 items from amazon.
To power the converter:
Converter itself:
As far as the rest; recently changed some HVAC bulbs. I'm painfully reminded that my 12V mod/reverse polarization project is still incomplete. Urghh.
I don't ever recall seeing my driveshaft move either with greasing it. Just put in a few squeezes, do one more, psyche myself out, call it good til next oil change.
The spider gears are easy. Just squeeze till it starts to come out.
picked up a set of Level 8 Tracker wheels for CHEAP!!!
They are used, but the wheels are almost brand new. not even one mark on them. The tires are about 30-40% left - ill get some tires later
17x8.5
cant wait to put them on!!!
The HID retrofit continues! All the headlight housing and projector shroud parts have been painted/baked with Duplicolor Engine Enamel. Did all the test fitments today and everything is looking great! Just need to run the High beam solenoid switch/demon eyes harness through a cable gland and I'll be ready to start actually putting them on the truck!
Today I drove my 4Runner home from the dealer - because I bought it today!!!
I am now a proud owner of a 2007 SE, with sunroof and towing package, with 143k miles.
Been a while since I posted in this thread..
Midland 75-822 and 3ft Firestik installed on a Diamond K400 mount. Also added toggle latches to the DIY drawer system to keep them from sliding out.
I have been on the edge of ordering Relentless fab rock sliders for the last week....
Just do it...
I told myself I'd get sliders once I got my truck. Always said no every time I was in the shopping cart with credit card in hand.... Eventually just pulled the trigger.......
And now I have sliders on the way. Isn't that lovely? :lmao:
Switched Alpine HU display color from default blue to amber
I was able to complete stage one of my Stock++ build last week by replaced XREAS/RAS with Metal Tech coil conversion kit, Bilstein 5100s, lightly used 2016 TE coil springs, and front and rear Moog sway bar bushings and links. This gives me exactly the lift I need for going to 32" tires in the future and provides a supple yet firm ride. I tried it out on the Iron County Recreation Trail (UP of MI) and really like the way it rides.
Sometimes the simplest changes can be quite satisfying. This is not even a mod, just a minor change in settings: I switched the display color of my Alpine HU from the somewhat harsh default blue to amber, which blends in perfectly with the backlit LCD display above the HVAC controls. I also reduced the brightness a bit.
Before:
IMG_20170616_122657
After:
IMG_20171019_145848
She is definitely a keeper! Not only would my wife not do that but if she saw me do it she would probably call me an idiot and say "why are you doing that, no one sees underneath"
I did the same, huge difference.
Tx470
