How much transmission fluid did you put in? It's such a PITA that I haven't done that since I replaced mine. It's only been a few hundred miles, however.
About a cup so far. Didn't lose much after pulling the hoses as I had plugs for them. Not sure how much was actually in the old radiator but i''ve been checking the level and it says full still.
Finally got my Timing Belt service done on my 2006 v8! @ 105K
Replaced w/ Aisin Timing belt kit:
Timing Belt
Tensioner
3 idler pulley's
Water pump
also replaced:
t/stat
serp belt
Upper and lower radiator hoses
installed the 30mm prothane greasable bushings i bought from amazon. my clunk got worse!.
guess i didnt do a good job. will remove and reinstall.
a quick question to folks who installed the greasble bushings -- did you pump grease into the nipple immediately?..did any grease seep out?
grease seeped out between the bushing and the u cover when i did mine,,,doesnt sound right
Finally upgraded to the 2015 brakes in the front and installed stoptech SS lines the whole way around. Installed my extended rear sway bar links and toytec brake lines. If feels good to have a firm brake pedal again.
Took care of the rust on the rear end of my 04 SR5. Bought it like this and decided to convert the rust using Corroseal and then undercoat with Rustoleum professional grade undercoating. Came out nice, but time will be the true test...
Before...
Right to left... Rust > Corroseal hard at work > Rust converted to Magnetite!
After undercoating...
Before...
That's what I want to do! I've been reading on the best thing to use.
Did you wirebrush any rust off or just spray over everything?
I wirebrushed all the loose rust off. The Corroseal gets applied with a paintbrush which is the hardest part of the job... especially without a lift. Lots of nooks and crannies when doing the rear axle. Frame is much much easier. And then the undercoating I used was in a spray can so that was pretty simple. The most important thing is to get the loose rust off, degrease everything, and use a high quality product like Corroseal. The spray on rust converters aren't worth shit in my opinion.
Weekend work
Upgrades I installed this past weekend:
New Radio - JVC KW-V330BT, and the iDataLink Maestro:
Extra USB ports to center console:
Installed some Focal PS 165V1 component speakers to replace the Infinity 6500cs speakers. Sounds great.
wassup with the speaker grill? do you guys really need to add another grill there when the door panel has one. how you liking your speakers? if you have a good deck or good amp, run the speakers active.
added another set of speakers, doing all active, go about 1277w RMS since im loading my amps at 2 ohms now, sounds pretty loud and clear at volume 50 with my deck that i set my gains at 59. these hertz sounding really nice, have my mids at 50hz to 2.5khz, tweeters at 2.5khz, lots of mid bass punch that you can feel to the chest. also i havent run my subs for a while since im still breaking this in.
4cfb90643746553
<a href="http://www.imagebam.com/image/4cfb90643746553" target="_blank"><img src="http://thumbs2.imagebam.com/c8/9f/c2/4cfb90643746553.jpg" alt="imagebam.com"></a>
